Old 07-07-2017, 02:57 PM   #1
tptwrc
Passenger Front airbag removal???
Why can I not find any instructions/DIY info to remove the passenger front airbag?? Please help
tptwrc is offline   Reply With Quote
Old 07-07-2017, 02:59 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
The one in the dash??
Old 07-07-2017, 09:20 PM   #3
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Here is how to remove the airbag module if that's what your looking for (semi-amateur way):
[ame="https://www.youtube.com/watch?v=lF0xcrt0n-E"]GT86 SUBARU BRZ SCION FRS AIR BAG MODULE REMOVAL REPLACEMENT AIRBAG MODULE - YouTube[/ame]
Here how to remove the driver's airbag:
[ame="https://www.youtube.com/watch?v=AAS_1a7sgvs&t=249s"]86/BRZ: How to Remove and Vinyl Wrap Steering Wheel Panel - YouTube[/ame]
FRS2017 is offline   Reply With Quote
Old 07-15-2017, 11:07 AM   #4
tptwrc
Isn't there an airbag positioned in front of passenger?...Thanks for trying but the ab module is electronics, not an airbag, and the other you posted is the steering wheel ab.
Old 07-15-2017, 02:27 PM   #5
FirstWinter
Drives: Car
It's fairly easy but for safety you want to disconnect the battery then press down onto the brake for 5-10 secs or until the brake light doesn't go off anymore.
What you do is take out the glove box and you'll see the airbag above. Disconnect the clips with a flathead screwdriver. To fully remove the airbag you have to take out the 2 10 mm(might be 12mm?) bolts and then try to unhook the metal part holding the airbag from the holes in the dash. This is a lot easier with the whole dash out but with some patience you can eventually pull it out. You can use the flathead to help pry it out.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
SuperTom (04-24-2018)
Old 06-11-2021, 12:28 PM   #6
q335r49
Drives: 2013 scion fr-s
Hey guys, is a resistor needed for the pass dash airbag to ensure the rest of the airbags don't malfunction?
q335r49 is offline   Reply With Quote
FS: Passenger Airbag Sehwan Kim Interior Parts (Incl. Lighting) 0 06-29-2016 09:21 PM
Passenger Airbag derek1ee Interior Parts (Incl. Lighting) 0 06-03-2016 01:30 AM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 12:26 AM
WTB Passenger Curtain Airbag + Wheel Airbag markkisl Want-To-Buy Requests 4 08-26-2014 01:16 AM
Airbag light stays on after removal/reinstallation Pablitomarrero Issues | Warranty | Recalls / TSB 13 04-04-2014 08:34 AM
