Old 07-05-2017, 11:02 PM   #1
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
ebay lip, protekt skidplate, or nothing?
Due to living on a hill and a f*cked up driveway angle I scrape my front bumper on a daily basis. Finally thinking about maybe doing something, but I'm not sure. My first thought was a CS style lip, but given that it will scrape every day I'm afraid it would end up in my driveway and/or just look sh*tty. Looking at pictures of the Protekt skidplates it looks like where they're mounted is a little far back to do me much good.
So...would a lip just get torn off/would Protekt do any good?
BRZyJ is offline   Reply With Quote
Old 07-06-2017, 02:24 AM   #2
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Lift your car an inch?
Scrappydoo is offline   Reply With Quote
Old 07-06-2017, 03:25 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
OP didn't state and hard to tell from pics IF it's lowered.
Old 07-06-2017, 03:51 AM   #4
broberg
broberg's Avatar
Drives: 2017 BRZ
Fix your driveway?
// Pierre Broberg
2017 Subaru BRZ, Christal White Pearl
broberg is offline   Reply With Quote
Old 07-06-2017, 03:53 AM   #5
swarb
Pics of the driveway
Old 07-06-2017, 04:57 AM   #6
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Irrespective it can still be raised by coils and/or tyre aspect ratio.
The Following User Says Thank You to Scrappydoo For This Useful Post:
Ultramaroon (07-08-2017)
Old 07-06-2017, 09:28 AM   #7
There are other options
Old 07-06-2017, 10:09 AM   #8
BRZyJ
BRZyJ's Avatar
Oops, yeah I should have mentioned...it's not lowered and has stock wheels/suspension. The driveway itself is in decent shape, I think it's that the hill is at a fairly steep angle so the driveway itself isn't anywhere near level...no matter how you enter, something will scrape
Old 07-06-2017, 10:35 AM   #9
Teseo
Drives: frs
Try again but with angle, your driveway is flat and i dont see the problem.
Teseo is online now   Reply With Quote
Old 07-06-2017, 11:38 AM   #10
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Lol obviously there is a problem, didn't you see the picture of under his bumper? He's not scraping the due to improper angle of entry.
his photo is not doing justice, and may look "flat" to you but there must be some incline...
OP, my 2 cents. (like you said) the Protekt's mount too far back to prevent the issue your having.
Id get a cheep lip or splitter/diffuser and see how cheese grated it gets, if it holds up you could get something more substantial.
VIP BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
BRZyJ (07-06-2017), Tcoat (07-06-2017)
Old 07-06-2017, 12:35 PM   #11
DAEMANO
Time Traveller
You're going to scrape with any low car on that driveway. You need driveway ramps.
https://www.bing.com/images/search?q...amps&FORM=IGRE
The Following User Says Thank You to DAEMANO For This Useful Post:
BRZyJ (07-06-2017)
Old 07-06-2017, 12:36 PM   #12
sirsol66
Drives: 2013 FRS- Hot Lava
Two suggestions:
1) Mask off the front facing portions of the bumper and rhino-line or similar the under side.
2) Run a slightly larger tire. I personally run 235/45R17's and the added height does wonders. Plus it fills up the wheel wells nicely if you dont plan to lower the car. Speedo/gear ratio will change a bit so just keep that in mind.
sirsol66 is offline   Reply With Quote
The Following User Says Thank You to sirsol66 For This Useful Post:
BRZyJ (07-06-2017)
Old 07-06-2017, 12:51 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Or google for "lift spacers brz"
The Following User Says Thank You to churchx For This Useful Post:
BRZyJ (07-06-2017)
Old 07-06-2017, 01:07 PM   #14
BRZyJ
BRZyJ's Avatar
That was google street view lol. The ones down below might give a better idea.
I may wind up doing that...if it gets torn off I'd only be out ~$60 or $70 or whatever.
Those I like...that would probably let me run a lip that might normally get chewed up or torn off. As long as nobody walked off with them...gonna check those out.
Originally Posted by sirsol66 View Post
Two suggestions:
I'll check that stuff out as well.
I just bought new tires a month ago...don't think that will fly with my wife, but maybe next time. Wouldn't mind filling it out a bit
Good ideas here, thanks guys.
The Following User Says Thank You to BRZyJ For This Useful Post:
VIP BRZ (07-06-2017)
2017 Toyota 86 ProTEKt skidplates now available!! mitch t Cosmetic Modification (Interior/Exterior/Lighting) 17 04-09-2017 08:39 AM
Installed My Protekt Skid Plate hapa_kcm Cosmetic Modification (Interior/Exterior/Lighting) 2 04-07-2017 03:26 PM
New ProTEKt skidplate kit for the Scion FRS RS1 mitch t Cosmetic Modification (Interior/Exterior/Lighting) 29 02-26-2017 02:22 AM
ProTEKt skidplates FT86club sale!! mitch t Exterior Parts - The Rest 1 01-11-2017 07:43 PM
FS: Protekt Skid Plate - BRZ harkbrz Canada Classifieds 1 12-10-2014 07:58 PM
