Old 07-05-2017, 09:48 AM   #1
Armin93
Drives: Toyota 86 GTS
Widest tyres you can run on 8
Whats the widest tyre that can be put on a 17*8+45 wheels?
Currently on 245 wanna go 255
Armin93 is offline   Reply With Quote
Old 07-05-2017, 12:32 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
One can choose & mount with insane stretch tires, and opposite also is true, with being able to mount tires way wider then manufacturers advise/suggest. Of course, with drawbacks, like mushy steering due too much side flex and such. Such "meaty" are sometimes choosed in racing class, where wheel dimensions are limited, but no limits on tire width choice, to get as much grip as possible within rules even with drawbacks for normal use/driving.
So "can" != "should".
By manufacturers for 8" by googled out tire width tables/calculators:
min 215, ideal 225 & 235, max 245.
Old 07-05-2017, 03:41 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
255 would look like you have flat tires.
You want to go wider you need a wider wheel.
Old 07-05-2017, 03:45 PM   #4
wparsons
wparsons's Avatar
Every tire has a min/max wheel size listed, look up the tire you want and see what the minimum wheel width is.
https://www.tirerack.com/tires/tires...Z232&tab=Sizes
flickr
The Following User Says Thank You to wparsons For This Useful Post:
mrg666 (07-05-2017)
Widest 0 offset wheels that will fit. Zer0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-01-2017 04:15 PM
Widest wheel on stock tires? JW843 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-21-2015 05:13 PM
Widest tire on 17x7? FRStock Tracking / Autocross / HPDE / Drifting 24 05-10-2014 01:20 PM
widest possible tires fish66 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-04-2013 01:41 PM
What is the widest tire for these wheels? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-12-2012 09:20 AM
