Old 06-25-2017, 03:35 PM   #1
Porygon
Drives: Scion FR-S
Tire pressure light not turning off
All four of my tires are at the correct psi. It just won't turn off. How do I turn it off? Any help is greatly appreciated. Thanks!
Porygon is offline   Reply With Quote
Old 06-25-2017, 03:47 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Are you checking the tires cold or after driving?
Old 06-25-2017, 04:04 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Are the wheels aftermarket or replacements? If so you might not have tpms sensors.
Otherwise my guess is a tpms sensor failed.
Also +1 to what jd001 said.
Old 06-25-2017, 04:57 PM   #4
cjny
Drives: 2016 BRZ
Either you don't have 4 functioning TPMS sensors or the system is malfunctioning. A bad sensor is the most likely problem but in any case it's a tough problem to troubleshoot on your own. You're probably going to have to take it to a shop with the right equipment.
cjny is offline   Reply With Quote
Old 06-25-2017, 05:22 PM   #5
Porygon
Drives: Scion FR-S
I was given 4 different tires when I got the car. They weren't brand new, but they were way better than the ones it had on.
Old 06-25-2017, 05:23 PM   #6
Porygon
Drives: Scion FR-S
I'm checking them cold.
Old 06-25-2017, 08:03 PM   #7
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
What about the actual rims though? TPMS are mounted to the rim itself (part of the air valve).
PandaSPUR is offline   Reply With Quote
Old 06-25-2017, 09:20 PM   #8
Porygon
Drives: Scion FR-S
Originally Posted by dominicpadawan View Post
The correct PSI indicated in the door is 35psi. Did you put 32psi or 35psi ?
All four are at 35psi. Just checked.
Old 06-25-2017, 09:22 PM   #9
Porygon
Drives: Scion FR-S
Actually they gave me the rims as well. But when I took it to a shop they told me that all four sensors were functional.
Old 06-25-2017, 11:18 PM   #10
PandaSPUR
PandaSPUR's Avatar
I think we need more background info here...
Did you just get your car? Was it used? Did you have to replace all four wheels (rims + tires)?
If the wheels are new (i.e. from another car), then the TPMS on them need to be synced with your car.
Old 07-02-2017, 11:52 PM   #11
Porygon
Drives: Scion FR-S
How do I go about syncing them to my car because all wheels came from another car. Thanks.
Old 07-03-2017, 03:42 PM   #12
cjny
Drives: 2016 BRZ
Not sure about the FRS, but on BRZ you need a tool to get the new sensors to sync. Easiest is to take it to a tire shop. They may do it for free.
Old 07-03-2017, 05:29 PM   #13
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Bingo
Scrappydoo is offline   Reply With Quote
Tire pressure light VABeachBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-11-2016 04:12 PM
Turning off air bag light s0sl0w Electronics | Audio | NAV | Infotainment 2 07-16-2016 10:24 PM
Low tire pressure light... Premium 615 BRZ First-Gen (2012+) — General Topics 27 01-20-2016 11:54 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
tire pressure warning light kinda wonky? chickdigger802 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-27-2013 12:00 PM
