Old 06-19-2017, 01:37 PM   #1
Launcher
Drives: Subaru BRZ Limited 2013
Wheel fitment (Fender lip roll)
Just got some tires/wheels for my Subaru BRZ 2013.
17x9 wheel 45mm offset
tire 245 / 40 all around
Tire rack support recommended I get a small fender lip roll.
I took it to a shop and they said they would do the lip roll after the tires are on and get a better idea on where to lip if needed anywhere.
I have read many threads and from what I can see, these should fit without issues on stock suspension but wanted to make sure they will go on the car when I get the wheels/tires.
If anyone has any experience with this setup tire/wheel please let me know. Otherwise, I need to find a different shop that will do this fender lip roll. I know its like $200 to just buy the roller but I would rather have a shop do it so I do not chip any paint...
The plan now, is to put on wheel/tire and look to see if it causes any tire issues and take it into the shop after and show them the issue.
17X9 ENKEI TUNING TM7 GLS BLACK
245/40ZR-17 MICHELIN PILOT SUPER SPORT XL
Stock suspension
Launcher is offline   Reply With Quote
Old 06-19-2017, 01:42 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
What is the offset of the wheel?
I'm running a 9.5" (+45) wide rear wheel with 255/35 AND lowered with no rubbing. You should be fine at stock height.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Tcoat (06-19-2017)
Old 06-19-2017, 03:16 PM   #3
Launcher
Offset is 45mm
I am thinking it will be fine then without needing to fender lip roll and assuming Tire Rack just said that to cover their end if for some reason there were issues.
Let me know what you think!
Old 06-19-2017, 03:23 PM   #4
swarb
Stock suspension
You won't need any fender roll. But you will need a 3-5mm spacer up front. 9 width and +45 offset rubs sway bar or tie rod under full lock.
The Following User Says Thank You to swarb For This Useful Post:
dattran86 (06-19-2017)
Old 06-19-2017, 03:59 PM   #5
dattran86
Driver
Drives: 2013 Whiteout FRS
to add to that, if you were to add a camber bolt up front,
you might need to get extended studs and run a 10mm or 5mm spacers, because 9 offset 45 is very tight up there.
And you dont need to roll your fender at stock height, even if you're lowered as well.
45 offset meaning the wheel sit closer to your suspension rather than your fender.
just slap the wheel on and dont worry about rolling anything.
This is me with 17x9 35 235/45/17 offset which is wider than your spec. and I am still on stock struts with RCE Yellow. It still have an inch wheel gap. no need to roll anything,
DSC_0539 by Apex 86, on Flickr
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
D_Thissen (06-19-2017), gramicci101 (06-20-2017)
Old 06-19-2017, 11:56 PM   #6
Launcher
So getting two 3mm spacers for the front should do it?
Old 06-20-2017, 12:09 AM   #7
swarb
Yes. But keep in mind that all cars aren't exactly the same to the MM. And that under extreme conditions(hard cornering/speedbumps/u-turns) your experience might be different. less than 3mm isn't exactly a lot of clearance, but many people have no problems. I personally wouldn't risk it as I purchased a used set of 17x9 +45 and the inside lip had 1mm+ of the inside lip scraped off(paint+metal), even with a 3mm spacer, there would be 2mm or less clearance.
Since you already purchased them, I'd tell you to mount them with 3mm spacers and put a flashlight under and see how much clearance you have and if you feel safe enough to use it like that.
Clipdat (06-21-2017)
Old 06-20-2017, 02:21 PM   #8
Launcher
So I am leaning away from 3mm spacers then it would suck if something bad happened.
Any coilovers someone can suggest that would bring the inside so it doesn't hit since that seems to be the issue at this point from what I am reading
Old 06-20-2017, 02:48 PM   #9
swarb
Anything with smaller diameter springs will work. Usually height adjustable type or type that comes with springs installed. Pretty much everything except "stock replacement"
Old 06-21-2017, 05:22 PM   #10
Launcher
I just purchased the KM Varient 3 coilovers assuming I should be clear now? Any input would be greatly appreciated.
The Following User Says Thank You to Launcher For This Useful Post:
Old 06-21-2017, 05:38 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
You'll be golden with the KW v3.
I was in the same position as you with 17x9 +45 3mm spacers, etc etc.
Originally Posted by humfrz
I'm old and lazy
Launcher (07-01-2017)
Rear fender roll in SJ? djdnz Northern California 3 04-25-2017 09:47 PM
Fender Roll/Pull FRS-IT Cosmetic Modification (Interior/Exterior/Lighting) 6 11-14-2014 10:45 PM
Daredevil Achieves First Barrel Roll In A Four Wheel Vehicle #944_10_Series_FRS Off-Topic Lounge [WARNING: NO POLITICS] 3 11-22-2013 09:43 AM
Fender Roll Ryaquinn Cosmetic Modification (Interior/Exterior/Lighting) 9 07-05-2013 05:49 PM
