Old 05-27-2016, 12:17 AM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ceramic Coating - keeps heat in or out?
I'm getting my exhaust manifold ceramic coated, and was wondering if I should get my aluminum intake pipe coated as well? Would ceramic coating help insulate the intake pipe from external radiant heat?
I'm asking because if ceramic coating only helps keep the heat in (i.e. within the exhaust manifold) rather than blocking out heat, then I would rather save my money and leave the intake pipe as is (chrome).
Fizz is offline   Reply With Quote
Old 05-27-2016, 12:42 AM   #2
swarb
Works for both. Probably won't do much for the intake pipe. Metal intake pipe is a bad idea either way.
Old 05-27-2016, 12:52 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Of zero consequence, since the intake tube is not a significant source of heat transfer to the intake air charge.
-alex
Old 05-27-2016, 01:35 AM   #4
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
i mean.. insulation is insulation. Works both ways, just straight up blocks the transfer of heat.
Not sure how much it'll really matter for the intake though
PandaSPUR is offline   Reply With Quote
Old 05-27-2016, 03:23 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks for the input guys. I'll be installing the SBD kit, which has the intake pipe running above the turbine housing (the plan is to ceramic coat the manifold, dump, and turbo housing). I guess I might as well get the intake pipe coated too.
Old 05-27-2016, 04:11 AM   #6
mav1178
mav1178's Avatar
If you do the exhaust components, there's virtually zero need for you to do the intake.
-alex
Old 05-27-2016, 04:15 AM   #7
504
504's Avatar
Drives: 2014 86 GTS
I personally believe anything in the engine bay will eventually equalise in temperature (engine bay ambient) so whether or not you coat the intake will only delay the time it'll take for the intake tube to reach equilibrium temperature. Focus on minimising engine bay ambient temps through header/exhaust wrapping and/or coating and thatll probably be the best result for you. Metal is also extremely effective heat conductor so you're battling against the elements in this case
Hope that helps
504 is offline   Reply With Quote
Old 05-27-2016, 06:28 AM   #8
ZZT86
ZZT86's Avatar
Drives: BR86
I can vouch for TC1 black ceramic coating of the manifold both internal & external, pretty decent reduction in under hood heat that's for sure.
ZZT86 is offline   Reply With Quote
Old 05-27-2016, 10:29 AM   #9
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The only thing we've seen make a difference is using gold heat tape on the intake pipe and manifold, even then it was only a few degrees.
Gear_One_Performance is offline   Reply With Quote
Old 05-27-2016, 11:20 AM   #10
OkieSnuffBox
Drives: '23 BRZ Limited
Exactly.
The volume of air and speed at which it is moving prevents any meaningful heat transfer from occurring.
Old 05-27-2016, 11:54 AM   #11
Gunman
Drives: 2019 Mazda Miata RF
Ceramic coating is a "thermal barrier", it does not care which side the heat is, it just makes a barrier for heat transfer.
Gunman is offline   Reply With Quote
Old 05-27-2016, 01:55 PM   #12
This.
ceramic coating eddiev116 NY / NJ / CT / PA 3 02-06-2015 05:54 PM
Anyone heat coating their headers? BenArmstrong Engine, Exhaust, Transmission 29 12-29-2014 01:15 AM
Ceramic Coating on Header? ELutz04 Engine, Exhaust, Transmission 37 06-05-2014 01:13 PM
Ceramic coating recommendations mrk1 Forced Induction 5 03-03-2014 10:51 AM
Ceramic Coating options or Jet hot coating brzadmir NY / NJ / CT / PA 4 07-10-2013 12:35 PM
