Old 06-15-2017, 07:27 PM   #1
KingD916
Drives: '15 FRS
Car will not start // Please help!!!!
Car sputtered on the freeway this morning like not was running out of gas. Going 65-70mph and rpms suddenly dropped to between 1-2k. Stepped on the gas and they came up momentarily but immediately dropped again like it was going to die. Pulled over and shut it off. Tried to turn on again and it cranks but would not start. Battery died after a few tries.
Got home and tried to jump it. Cranks fine but will not start. Charged the battery for a lil bit but same thing, cranks super good but will not start.
Plenty of fuel and I've checked all the fuses. No blown fuses. Car is a 2015 FRS. Any other ideas to check for before I get her towed to the dealer?
KingD916 is offline   Reply With Quote
Old 06-15-2017, 07:58 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
How'd you get it home after it died on the freeway?
shiumai is offline   Reply With Quote
Old 06-15-2017, 08:01 PM   #3
humfrz
Hello KingD916 and welcome to ...... The Forum .......
hmmm....... let's see.
* do you have any power mods .. ??
* what's the last thing you did under the hood before it started acting up .. ??
* how long before it stopped did you put gas in it ..??
* is the car showing you any codes ..... if so, what .. ??
* is the check engine light on ..??
Come back.
humfrz
Old 06-15-2017, 09:33 PM   #4
stevesnj
stevesnj's Avatar
Pull the negative battery cable for 30 min and hook back up and try again.
My 2016 Build thread
Old 06-15-2017, 11:22 PM   #5
humfrz
....... maybe it was downhill all the way ......
humfrz
Old 06-15-2017, 11:27 PM   #6
Gforce
Drives: 2013 Subaru BRZ
Er, warranty. Roadside assistance is included, is it not?
Gforce is offline   Reply With Quote
Old 06-16-2017, 12:15 AM   #7
KingD916
Drives: '15 FRS
I had it towed lol.
Fuel was halfway between 1/4 tank and empty. Put 2 gallons in and now it's at the 1/4 tank mark and starting and running fine. That's the only change I made. Only verified everything else.
Can't be the gauge being slightly off could it? Maybe the float? I'm just throwing ish out right now that would make sense but I'm not totally convinced this is the cause.
Old 06-16-2017, 02:38 AM   #8
humfrz
I had it towed lol.
Well, now, if your car is running fine ...... now that it has some gas ... ...... and it's not showing any codes ..... I would suggest you take it and fill up the tank and drive it.
If it runs through a tank of gas with no problems, you may be good to go.
About the gas gauge ...... it might be off. I would suggest you never let it get below a 1/4 tank.
humfrz
Old 06-16-2017, 06:28 AM   #9
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Odd thing about the gas gauge. The low gas light should have turned on.
Mine turns on at the halfway mark on the 1/4 line towards empty.
Maybe the floater sensor got messed up? Either way you can cheap out and just don't let it get below 1/4. Or throw money at it to fix it.
Old 06-16-2017, 09:40 AM   #10
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i would take it to dealer if you're still under warranty
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
