Old 06-15-2017, 12:54 PM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Please help on my oem brakes
So my car is making a weird noise from the front left (like a slight rubbing/scrapping) when braking or when driving. A mechanic checked my brakes and found that my rotors are starting to go. He mentioned that i still have some more life on them but the sound will just get worse and eventually i will have to replace it..
Im running the OEM brakes and pads & car is at 30k.
Not looking to spend too much money as i barely use my car now but when i go on mountain drives i push the brakes hard.
I found this http://www.ft86speedfactory.com/stop...l#.WUK0iRiZM0o
Would that be good enough? Im in between the stop tech or the hawks, have not buy brakes before so im just looking for some input. Thanks.
Jfheisenberg is offline   Reply With Quote
Old 06-15-2017, 01:10 PM   #2
strat61caster
strat61caster's Avatar
imo no, I wrote something up on the reddit that I'll link here. OEM blank replacement rotors are like ~$170 for a full set, stoptech pads on their own are like $130 for a full set, the rotors in that kit are overpriced and the stainless steel lines aren't useful for a DD so you're overpaying by about $200, and you still need to buy brake fluid.
https://www.reddit.com/r/ft86/commen...th_it_for_500/
I'm skeptical your rotors are shot, I've got 60k miles on mine, 5 track days, ~3 seasons of autox, I put over 30k miles on the stock pads (2x track days, about 1 season of autox) and they still have life left but I roasted the pads so they weren't gripping well anymore. If it's a brake pad dragging what needs to happen is the caliper slider pins need to be cleaned and regreased, maybe an hours worth of labor, a pad and rotor swap without cleaning the pins would make the noise worse and wear out the new equipment faster.
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
gramicci101 (06-15-2017), Icecreamtruk (06-15-2017), Jfheisenberg (06-15-2017), soulreapersteve (06-18-2017), Teseo (06-15-2017)
Old 06-15-2017, 01:13 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
See if someone will do a kit with a quality brake fluid like Motul, stoptech pads, and centric premium blank rotors. The slotted rotors will be of no value to you, and the stainless lines offer a very minimal improvement until you've got lots of miles on them.
The stoptech components are very good, I personal run their street performance pads, and I'm very happy with them.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-15-2017, 01:19 PM   #4
gramicci101
Off Topic
Your rotors are shot at 30K? That sounds sketchy given how you say you use your car. My first thought for the dragging noise was a pebble stuck in the dust shield, but presumably even that mechanic could spot that.
The Following User Says Thank You to gramicci101 For This Useful Post:
strat61caster (06-15-2017)
Old 06-15-2017, 02:32 PM   #5
Jfheisenberg
Interesting, wouldn't a pebble loose itself? Been like that for about 1 month.
Old 06-15-2017, 03:24 PM   #6
That would account for one but both sides at the same time would be beyond coincidence.
Not a hope in hell rotors would be gone but pads still OK after that few miles. Any chance you can get a picture of at least the outside visible parts for us? I doubt the mechanics diagnosis. Even if they were in some way damaged that would be a symptom not a cause.
Icecreamtruk (06-15-2017), Jfheisenberg (06-16-2017), Qadthane (06-15-2017), strat61caster (06-15-2017)
Old 06-16-2017, 02:21 PM   #7
Jfheisenberg
Thanks yes i know something is not right and i cant find what it is. Im at AZP installs in jersey right now, hope they can figure it out and finally b over with this issue
Old 06-16-2017, 02:46 PM   #8
gramicci101
Off Topic
AZP are good people. They'll figure it out.
Old 06-16-2017, 03:27 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
it could be hub/dust shield that touching rotor? check that out
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Gforce (06-16-2017)
Old 06-16-2017, 06:23 PM   #10
Gforce
Drives: 2013 Subaru BRZ
Most likely caused by the pads moving around slightly and touching the no wear ridges at the outer and inner limits of the pads as they wear the rotor. Modern asbestos free brake pads wear rotors quite aggressively. I note that the rotor surface rusts quite quickly if you do not drive regularly. That causes the rotors to wear a little faster then if you drive regularly. Rust can also make noise but only for the first brake application or two after the car has sat for a few days. Not likely your front brakes are worn out just yet even if you drive like a maniac, these are light cars with big front brakes for their size.
Rotors are designed to last only for about one set of pads with a bit of extra thickness to allow for variation in braking habits.
Seizing calipers make a knocking sound and you can feel the rotor runout through the brake pedal as well. It is unlikely your calipers are seizing at this young age.
I recommend you brake harder than you are accustomed to, at least a few times a month. This will help reduce brake noises
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
Jfheisenberg (06-17-2017)
Old 06-16-2017, 08:54 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
"Rotors are designed to last only for about one set of pads with a bit of extra thickness to allow for variation in braking habits"
Really? You are not into business selling brake disks by chance?
The Following 2 Users Say Thank You to churchx For This Useful Post:
Cole (06-17-2017), gramicci101 (06-17-2017)
Old 06-16-2017, 09:16 PM   #12
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
https://www.yourmechanic.com/article...otor-disc-last
I highly doubt your rotors are bad. Shady shop/ mechanic alert... Another reason I always do my own maintenance.
Helios is offline   Reply With Quote
The Following 2 Users Say Thank You to Helios For This Useful Post:
Cole (06-17-2017), strat61caster (06-17-2017)
Old 06-17-2017, 09:05 AM   #13
Gforce
Disc life varies. Generally speaking modern discs are designed to minimum weight for a few good reasons. You will likely wear out your discs before the second set of pads is fully worn out. Fitting harder pads makes this even more likely. Unless you know what you're doing you probably won't realize this.
Because discs should be machined if only to remove the no wear ridges and they are no longer thick enough to tolerate machining when worn by one set of pads, competent brake mechanics advise replacement as a more cost effective and safer solution.
Most drivers fail to realize that replacing discs with each set of pads is now the safer recommendation. You are free to endanger yourself if you wish.
Old 06-17-2017, 09:19 AM   #14
Jfheisenberg
So took the car to AZP yesterday and they did not found anything abnormal. They took the car for a ride and they claim its just road noise. The only thing that they found is that my front tires pressure was set to over 50psi. I did not think of checking that before, but when i got my summer tires installed those idiots must have over fill the tire pressure.
Anyway, i do think the sound is not as bad as before (although i still need to drive the car a bit more), however AZP did also mentioned that my tires are starting to get 'road dry' meaning that i should start thinking on replacing my tires at some point. But no budget for tires right now so thats gonna have to wait until next spring so i can do the wheels/tires and possibly brakes.
The Following User Says Thank You to Jfheisenberg For This Useful Post:
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 04:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 04:52 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
