Old 06-11-2017, 03:57 PM   #1
Ryder86
Ryder86's Avatar
Drives: 2015 BRZ Limited
STX Legal LCAs
Dropping my car 1" with Billstein/ RCE Tarmacs and wanted to set it up right for street and legal-STX autocross.
It seems like a lot of guys go with the Cusco LCA, but I'm pretty sure it's illegal in STX due to the pillow ball.
Just spoke with RacerX and they no longer offer the urethane rod ends to stay legal.
That leaves me with Velox and RSR. Do STX drivers really care about one set of pillow balls or should I just go with the Cusco.
*** I would prefer to run a steel LCA, as aluminum will transfer much more NVH.
Would love to hear your thoughts...
Ryder86 is offline   Reply With Quote
Old 06-11-2017, 04:02 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That leaves me with Velox and RSR. Do STX drivers really care about one set of pillowballs or should I just go with the Cusco.
Would love to here your thoughts...
Local or at Tour/Nats? Probably better asked in the STX thread or regional forums (or the FB group/forum for whatever grouo you plan to run with).
Also likely depends if you are winning trophies or not lol
Old 06-11-2017, 04:04 PM   #3
strat61caster
strat61caster's Avatar
There's also the cheap SPC lcas that you can get a press in STX legal bushing for. But if you're running locals it would take a real **** to protest you, there's not much to be gained by going to rod end there imo.
ineedyourdiddly
Old 06-11-2017, 06:09 PM   #4
redlined600
redlined600's Avatar
Drives: Fr-s
The whiteline lca should be legal and are very similar to the SPC units. Not so expensive either.
http://www.ft86speedfactory.com/whit...l#.WT2_SstOlnE
Old 06-11-2017, 07:08 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
It seems that they are not similar, just rebranded (and Eibach's too), and only thing that differs, paint color and slightly kit parts. Whiteline's seems to have additional eccentric bushing inboard, SPC's seems to have extra eccentric toe-arm bushings & slightly cheaper.
Old 06-11-2017, 07:46 PM   #6
Ryder86
Ryder86's Avatar
The Whiteline and the SPC both use an adjustment mechanism I hear is not optimal under stress and can be a pain to adjust. If this is not the case, please correct me. I thought an adjustable arm like the CUSCO, RSR, RACERX, SPL, VELOX, etc would be worth the money if adjustment and install was simpler.
That said, I know that spherical bearings and pivotballs perform better, last shorter, make noise (eventually), and are not STX legal.
Help a brutha out...
Old 06-11-2017, 08:11 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Might not be optimal .. but they also have one nice bonus - they look almost same as stock. By local MOT inspection rules i was told that with most of your aftermarket LCAs with better adjustment mechanism i'd fail, even if with normal bushing instead of pillow-ball. Even if alignment adjustment with those indeed is much simpler/quicker. Passed local yearly inspection with SPC LCAs just fine.
Old 06-11-2017, 08:31 PM   #8
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
What about Megan?
Lunatic is offline   Reply With Quote
Old 06-12-2017, 11:26 AM   #9
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
As already mentioned, the Whiteline LCAs are STX legal, and the SPCs can be legal if you change the bushing. For local events, no one will probably care if you ran unmodified SPCs. And yes, any LCA with pillow balls isn't STX legal for our cars.
Originally Posted by Lunatic View Post
What about Megan?
The Megan LCAs aren't STX legal.
G_Ride is offline   Reply With Quote
Old 06-12-2017, 03:00 PM   #10
Lunatic
Lunatic's Avatar
OK, thanks for setting that straight.
Old 06-13-2017, 10:15 AM   #11
bhmax
Drives: 13 BRZ, 17 Focus RS
I'm also planning on Tarmac/Bilstein setup soon. Are aluminum LCAs that much more noticeable as far as NVH compared to steel? No experience with that. I found some Precision Works Al LCAs on eBay that have STX bushings included. I can't find a website for them or any info on here though. Currently planning on them and Whiteline toe arms that include the lockout.
bhmax is offline   Reply With Quote
Old 06-22-2017, 08:37 PM   #12
Sononate
This may not be the right place for this and I apologize for butting in, but I'm desperate for help. I was gifted a set of Voodoo 13 LCAs, which I learned weren't legal for STX due to the spherical bearings. Does ANYONE know how I can get my hands on a set of left hand threaded polyurethane bushings that fit the voodoo 13s to keep it legal? I offer my unborn first child for the solution.. lol
Sononate is offline   Reply With Quote
Old 06-23-2017, 02:56 PM   #13
strat61caster
Even with the correct rod end I wouldn't call those legal as they move suspension mounting positions away from OE specs for "18mm of drop" (looks like swaybar and damper points are offset lower from where they would be on OE). I believe it's 14.8.H.5 that precludes altering mounting locations.
However, if you know the thread size you might get lucky and there's an off the shelf generic rod end that works. Start googling for "polyurethane rod end" with the correct dimensions and something might come up.
https://www.summitracing.com/parts/h...VPJBoCJ4Tw_wcB
Alternatively I'm thinking a local shop might be able to fab something up, I've read some tutorials about pouring your own polyurethane bushing so if they can weld a threaded rod onto a metal donut you could make your own if you're hardcore DIY which I've thought about doing, but I'm sure it's a pain in the ass.
Easiest solution would likely be to sell 'em and buy legal arms.
ineedyourdiddly
Sononate (06-23-2017)
Old 06-23-2017, 09:57 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
Precision Works is a stolen design with inferior materials. Can't recommend.
Also the toe arms aren't legal if that matters, they add adjustment range. The lockout is to keep the end in the stock slot from moving, since you no longer need it to adjust to.
The Following 2 Users Say Thank You to cjd For This Useful Post:
bhmax (06-25-2017), strat61caster (06-23-2017)
ISC V2 Rear LCAs New avishenoy1 Brakes, Suspension, Chassis 0 04-24-2017 07:21 PM
Do you think I will need LCAs? FaDuck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-06-2017 11:54 AM
question on SPC LCAs DuMa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 01-05-2016 06:36 PM
Front LCAs kalamitykode Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-04-2015 04:19 PM
WTB: OFT and Stance V2 LCAs Bergen23 Canada Classifieds 8 06-13-2015 12:01 AM
