Old 06-06-2017, 09:59 PM   #1
artongdou
Drives: 2017 Series.Yellow
Question Camera mounting position for track day
All I want is to capture at least my steering input and the track through windshield or side window with only one camera, most likely GoPro. I am gonna use Harry's lap timer for timing stuff. And the nice thing about it is that it allows video overlap.
So my question is where should I mount the camera? I am really looking someone with a snapshot and where the camera is mounted so that I can get a feel of it.
Thanks!
artongdou is offline   Reply With Quote
Old 06-06-2017, 10:07 PM   #2
spike021
spike021's Avatar
Maybe the driver-side quarter window?
spike021 is offline   Reply With Quote
Old 06-06-2017, 10:19 PM   #3
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
if i were to do it, i'd use a go pro somehow mounted to the headrest post, so it extends to the center of the car on your right
i'm sure someone makes a jig
tacos is offline   Reply With Quote
The Following User Says Thank You to tacos For This Useful Post:
artongdou (06-07-2017)
Old 06-06-2017, 10:30 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Rear windshield suction mount is fine for 99% of the cameras out on the market.
[ame="https://www.youtube.com/watch?v=lr3901PZCQA"]2:07.152 - Buttonwillow Raceway Park - 9 April 2016 - YouTube[/ame]
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
artongdou (06-07-2017), OND (06-06-2017), trippinbillies40 (06-07-2017)
Old 06-06-2017, 10:33 PM   #5
OND
OND's Avatar
Drives: 2023 BRZ
Passenger quarter window, suction mount, 1080p, medium FOV:
[ame="https://www.youtube.com/watch?v=1K7Km8kCtkA&t=338s"]BRZ and Miata dancing in the rain - Harris Hill Raceway - 6.4.2017 - YouTube[/ame]
Good for driver inputs, not so good for seeing the track. You probably also want to turn on spot metering. I left it off and got away with it due to overcast weather. Need the windows closed to hear the engine.
The other option is driver side quarter window on the outside. That shows more of the track while including all driver inputs, but the A pillar in the middle of view kinda bothers me. Wind noise is also pretty terrible.
OND is offline   Reply With Quote
The Following User Says Thank You to OND For This Useful Post:
Old 06-06-2017, 10:38 PM   #6
mav1178
mav1178's Avatar
I disagree, the problem with this view is you cannot see your gear shifting if you have manual.
[ame="https://www.youtube.com/watch?v=jDf0bUg-bpQ"]Circuit of the Americas - 29 April 2016 3:00.78 in my Subaru BRZ - YouTube[/ame]
Old 06-06-2017, 10:41 PM   #7
navanodd
Drives: 2013 BRZ Sport-tech WRB
This sounds like the best bet to me.
navanodd is offline   Reply With Quote
Old 06-06-2017, 10:48 PM   #8
OND
OND's Avatar
Drives: 2023 BRZ
Yeah, just checked and the shift knob area is mostly blocked by the helmet in my vids too. I mount the Gopro a little differently and use wide FOV for that position, but still...
Also, COTA in the BRZ
The Following 2 Users Say Thank You to OND For This Useful Post:
artongdou (06-07-2017), mav1178 (06-06-2017)
Old 06-07-2017, 09:28 AM   #9
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
+1 for upside down hanging from the rear window for track days:
[ame="https://www.youtube.com/watch?v=PE7uy-tvOxA"]Putnam Park 5/4/14 With 10/10ths Motorsports - YouTube[/ame]
For autocross, I tend to put it on the outside quarter window so I can see how close to cones I'm getting, at least on the left side.
[ame="https://www.youtube.com/watch?v=it1Mcvg1Ays"]2015 Solo Nationals 140 STX - YouTube[/ame]
If you're going to mount it inside, be sure to turn on spot metering. Otherwise you'll get a beautiful shot of your dash and a completely blown out exterior.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
artongdou (06-07-2017), CarzCarzCarz (06-07-2017)
Old 06-07-2017, 09:32 AM   #10
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
speak softly and carry a big stick.
http://jalopnik.com/subaru-dealer-ho...ing-1795828438
thomasmryan is offline   Reply With Quote
Old 06-07-2017, 10:00 AM   #11
Joon525
Joon525's Avatar
Drives: 2016 BRZ
I have this.
I don't use it for track purposes, it's more for a photography project and I'm a little concerned that it may not be sturdy enough with my camera on it but for a GoPro? Probably no problem.
It's cheap enough that if it doesn't work out it's not a huge loss.
Joon525 is offline   Reply With Quote
Old 06-07-2017, 10:24 AM   #12
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Rear windshield, hanging upside down.
Or create a headrest mount easily - tube, two u-clamps, drill some bolts into it, use a washer and nut to secure the u-clamps, put a go-pro plastic receiver mount on the other end of the tube.
You will want some sort of damping for vibrations on this set up. My footage gets a little shaky at faster run groups.
Jyn is offline   Reply With Quote
Old 06-07-2017, 10:59 AM   #13
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
I just use the gopro suction cup mount at the top of the rear windshield, works great.
[ame="https://www.youtube.com/watch?v=WuEVsnzop3E"]https://www.youtube.com/watch?v=WuEVsnzop3E[/ame]
Yanbags is offline   Reply With Quote
The Following User Says Thank You to Yanbags For This Useful Post:
Old 06-07-2017, 11:34 AM   #14
OND
OND's Avatar
Drives: 2023 BRZ
That sounds pretty awesome, where did you put the mic? I'd also consider a narrower FOV to see more track and less interior.
100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) zthang DIY (Do-It-Yourself) Guides 10 12-18-2015 04:14 PM
SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness NanDAssi Audio/Visual, Electronics, Infotainment, NAV 5 11-24-2015 05:06 PM
What position do you sit in FR-S/BRZ??? cry7670 Scion FR-S / Toyota 86 GT86 General Forum 25 05-09-2015 12:08 PM
Video/Go Pro Camera Mounting and locations diirk FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-02-2012 08:33 PM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
