Old 06-06-2017, 09:41 PM   #1
radiiantly
Drives: 2014 BRZ
DELETE THREAD
So I was looking into buying 5x114 adaptors, but I'm a little iffy on what the conversion will do?
Anyone know any cons or reasons for why I shouldn't buy them?
radiiantly is offline   Reply With Quote
Old 06-06-2017, 11:06 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
They will make your new wheels stick out. Usually no one ends ups liking them. The whole mounting an extra hub on a hub usually ends up eating hub bearings over a long or short time depends on the abuse.
It's like running a thick wheel spacer. Unless you get a whole new hub with 5x114 just buy the right blot size wheels.
In the end save up, and just drop that extra cash on the proper wheel offsets/size.
Old 06-06-2017, 11:42 PM   #3
radiiantly
Drives: 2014 BRZ
Gotcha, thanks!
Old 06-07-2017, 12:09 AM   #4
Impureclient
Drives: 2015 FR-S
If wheel spacers ruin bearings, why doesn't changing to wheels with less offset do the same?
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
gramicci101 (06-07-2017)
Old 06-10-2017, 08:43 AM   #5
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
It's usually done so you can put a wheel on the car that is only available in 5x114. If you wanted to run, say, a 5x114 Toyota Supra wheel on your BRZ, the simplest way to do that would be with a bolt-on wheel bolt pattern adapter.
Pros: They are relatively simple to purchase and install. They are completely reversible.
Cons: They are not cheap. They are at LEAST 15mm thick. Your original spare tire will no longer work. If they are less than 20mm thick, the original studs may poke out into your wheels.
They will be pushed out, but whether or not they stick out depends on the width and offset.
That's kind of a broad statement.
I have not observed this to be the case.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-10-2017, 11:29 PM   #6
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
I'm running a 25mm and 50mm adapter for over a year and half now and have had no issues with them whatsoever.
Johnny. is offline   Reply With Quote
Old 06-11-2017, 04:14 PM   #7
radiiantly
Drives: 2014 BRZ
Thanks this actually helped a lot!
5x100 to 5x114.3 wheel spacer adaptors 25mm Evasivegt86 Brakes, Suspension, Chassis 20 08-07-2015 01:44 PM
20mm adaptors Low&Slow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2014 02:47 PM
fs id1000s w pnp adaptors/gs ebc/omni 4 bar kingkai23 Engine, Exhaust, Bolt-Ons 10 06-09-2014 09:27 PM
PCD adaptors Astra^EC AFRICA 9 03-24-2014 02:50 PM
5x114 conversion adaptors GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-27-2013 08:35 PM
