Old 06-05-2017, 01:26 PM   #1
golemslord
Drives: 2014 White FRS
What mm spacers for flush ??
Im currently on trd springs (1 inch drop) and trd wheels that are 18x7+35 FRONT and 18x7.5+35 REAR. I want to make the car look more flush but not sure what mm I should get. I know that stock wheels require 20mm front and 25mm rear. Any help would be great, thanks
golemslord is offline   Reply With Quote
Old 06-05-2017, 01:57 PM   #2
DAEMANO
Time Traveller
With 35 offsets you should be very near flush right now (within 5-8mm). Adding 20-25mm's more offset will get you poking at both the top and bottom of the tire. My guess is your definition of flush and mine are different.
My recommendation would be that you take a tape measure to top edge of each tire and measure to the inside of each fender to get an idea of how much more your wheels need to be pushed outwards.
You can also use the wheel spec simulator normally located here (but it appears to be down atm). It's not always bang-on perfect, but helps.
The Following User Says Thank You to DAEMANO For This Useful Post:
golemslord (06-05-2017)
Old 06-05-2017, 05:30 PM   #3
KnightRyderx2
Drives: 2014 FR-S
Doing some math and what I have seen with my car, I would say 10mm all around.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
Old 06-05-2017, 06:00 PM   #4
golemslord
But does 10mm spacer exist for our cars ? I heard it doesnt fit ? Its also not an option when i wanted to select a size for spacers. Thanks
Old 06-05-2017, 06:51 PM   #5
DAEMANO
Time Traveller
You can get spacers in just about any width. The issue with our cars is that the stock wheel studs are only long enough to accommodate 3mm to maybe 5mm spacers at most. For thicker spacers pressing new extended studs into the wheels is necessary. OR you could install bolt-on spacers, just make sure to get very high quality ones and also ensure that the wheels you're using have pockets in the back that will accept the nuts from the installed wheel spacer (in the pic below, notice the wheel on the left has a sharpie one of the pockets between the lug holes). This wheel is bolt on spacer friendly.
Cole (06-05-2017)
Old 06-05-2017, 08:01 PM   #6
KnightRyderx2
Drives: 2014 FR-S
You will have to get slip on type spacers with extended lugs. When using a bolt-on type spacer the oem lugs will hit the back of the wheel even though the wheel has wells to accommodate.
Old 06-05-2017, 08:26 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
"flush" depends entirely on your alignment specs and how you view "flush" relative to the body. everyone has a different ideal of what this means.
back when I started doing car stuff, "flush" was basically anything up to (and including) the front face of the wheel forming a straight line with the outermost edge of the fenders. often times I would make things more "flush" or buy more room for wide wheels by rolling/pulling the fenders out.
To each their own...
Can I get this flush? BRZBYE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-24-2016 06:26 AM
Not flush panels FRSure Issues | Warranty | Recalls / TSB 9 02-20-2016 01:27 AM
*H&R* Wheel Spacers | Get Flush | 5mm - 30mm | GREAT PRICING!! Kami Speed Wheels and Tires 105 12-30-2014 02:32 PM
RPF1 most flush? goshem Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-27-2013 10:34 AM
Flush +/- DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 11:37 AM
