Old 06-04-2017, 12:30 AM   #1
KRC 9
Drives: 2013 silver BRZ
FS or trade: 981 Cayman S
Hello ft86club, it's been awhile. I had a 2013 BRZ (silver, premium, 6-sp) and would like to get back into one as I am faced with selling my Porsche 981 Cayman S. Hoping to find a BRZ enthusiast who has done proper maintenance and added some suspension mods, header, tune, etc. and is looking to get into a Cayman. I would like to gain a nice BRZ + cash. Asking $57,000 outright.
2014 Porsche Cayman S - 981CS. CPO until 4/29/2019. Approx. 10,220 miles. White exterior, black interior. Following optional equipment: sport chrono pkg, sport design steering wheel, sport seats plus (2-way), 20" Carrera S wheels with painted Porsche center caps, wheels painted platinum satin, guards red seat belts.
Additional original and aftermarket equipment: GT3 front lower control arms with solid caster puck, 991 GT3 front sway bar (3 position adjustable), Tarett Engineering 5-position adj. rear sway bar, Tarett adjustable droplinks front and rear, Bilstein PSS10 coilovers, motorsport front brake caliper stud conversion, Porsche 991/981 clear LED corner markers, 7mm wheel spacers all 4 corners with longer lug bolts, Weathertech floor liners (black).
Setup: weight with 180 lb driver and 3/4 tank - 3,231, corner balanced within 1 lb. Alignment -2.5 camber front, -2.0 camber rear, 0 toe front, 1mm toe in rear each side.
All original suspension components will go with the car, as well as the original amber corner markers. The carpet floor mats still have the plastic covering and also go with the car. I can send additional pics upon request.
Best regards, Kyle
KRC 9 is offline   Reply With Quote
Old 06-04-2017, 12:36 AM   #2
imnotsureaboutbrz
Drives: between cars...
I gotta ask... why? To a lot of people, including myself, see this car as the next 'step up' from the 86 sports car platform. Why the urge or desire to go back? If it's a finacial decision I could see, I just want to know what you missed?
imnotsureaboutbrz is offline   Reply With Quote
Old 06-04-2017, 12:42 AM   #3
KRC 9
I will be sorely missing this Cayman. It is purely a financial decision. I also had fond memories of my old BRZ and find it will still feed the driver enthusiast in me, absent the Cayman.
Old 06-04-2017, 05:59 AM   #4
Franky_Four_Fingers
Franky_Four_Fingers's Avatar
Drives: 2015 BRZ Blue Edition - P&L Turbo
Great car, great seller. GLWS Kyle!
Franky_Four_Fingers is offline   Reply With Quote
Old 06-04-2017, 07:19 PM   #5
MrsJames
So. Many. High-heels.
Drives: 2016 Halo FR-S
Would you consider a 16 FRS? I'm looking to move into a 981 C2S and I'm in Chicago
MrsJames is offline   Reply With Quote
Old 06-05-2017, 06:40 AM   #6
KRC 9
I prefer the BRZ, but would consider a FRS. See PM.
Old 06-05-2017, 09:50 AM   #7
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Even beyond financial, sometimes you just want a car you can build yourself or work on yourself or is more playful and fun on the track. I have tracked many o'cars, and the cheaper ones allow to have a more fun day at the track sometimes, and you can push them with less worry financially.
My 987 and 981 were very capable, but I have gone back to a BRZ twice now. Now do I still want a P-car...sometimes, and I am sure one day we will have one again. But right now, I am becoming a better driver with my S2000 and BRZ. In fact when I get the chance to drive a P-car on the track...wow, I truly am much faster. A lot of my local PCA guys have become stagnant in their driving ability. I went back to a MIata and a BRZ for a while, when I came back to P-car I was much better.
Its strange, but once you can afford to move up in cars, sometimes you miss the simplicity of the less expensive ones.
OP - GLWS - The good thing is both cars are fun. If I was in the neighborhood for another P-car, I would work something out with you. But, we are waiting about 5 years before dumping the BRZ and moving back to a Cayman or other model.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 06-05-2017, 10:16 AM   #8
bsubaru21
Drives: 2008 WRX STi
PM sent
bsubaru21 is offline   Reply With Quote
Old 06-24-2017, 11:39 PM   #9
KRC 9
Bump for price change.
Old 06-25-2017, 02:06 AM   #10
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
woo boy, wish i could afford that. GLWS
PandaSPUR is offline   Reply With Quote
Old 06-25-2017, 10:35 AM   #11
Franky_Four_Fingers
Same here. Definitely one of the best looking Caymans I've seen, plus it already has all the track mods I'd want!
Old 06-25-2017, 10:36 AM   #12
KRC 9
Brzaapi hit on many valid points between the FT86 and pcar 98x platforms. They both are so capable in daily driving AND track duty with just a few simple mods. You can take them to more extremes, albeit the FT86 is more mod-friendly power wise. I personally would never boost an otherwise stock Porsche 9A1 flat six.
Running costs are higher for the 981. Mainly, tires and brakes. Engine cooling is ready to go from the factory in the 981.
I haven't driven a FT86 with a good coilovers setup, so can't compare to how the 981 handles. My '13 BRZ had the RCE yellow springs with Koni yellows and camber bolts and spc rear arms to dial in the camber settings. It was a ton of fun at that level of modification. The responses of both cars is incredible, just that the speeds are higher for the 981. Last event I couldn't 'quite' keep pace with a 500awhp evo that was running a sq 275 rcomp setup, caged, lightened, etc. I did get the point by from a welldriven LS swap RX7 who had some aero in the form of a large rear wing. Point being, without serious power mods, a BRZ would be very hard pressed to run with those cars, but driving the 981 well can get you there.
Lastly, I started out learning with a '93 Sentra SER, just barely touch the brakes and keep the throttle pinnned...great times in that car. Moved to b5 A4 (APR st3, coilovers, stoptechs), then 951 (maintenance pig), BRZ, then 981. Except for the maintenance hassles of the 951, all have been terrific. Finallly, never owned a S2000, and have a ton of respect for those and would want to check one of those out too.
Old 06-25-2017, 11:17 AM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A new 718 Cayman with same optional equipment (20" wheels, sport seats plus, sport chrono) has a total retail price of $62,030 and a much lower actual price. Performance wise is also very similar to your car and has much better consumption and CO2 results. The price of your offer seems quite high and cannot be justified by the aftermarket parts. I am afraid that your car was seriously devaluated by the much better offering of the newer model.
Old 06-25-2017, 11:29 AM   #14
KRC 9
Reliability with the dual uses remains to be seen with the 718. Drive ability is already proven to be different between the two and both have a market.
Thanks for your reply.
BRZ vs Cayman/Corvette Norcalkid FR-S / BRZ vs.... 128 01-31-2017 12:36 PM
2006 Cayman S for sale/trade jordyking Cars for Sale/Trade 10 03-04-2015 09:45 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 04:49 PM
