Old 07-17-2012, 01:26 PM   #1
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
pulley installed issue
ok so my problem comes by installing perrins pulley i cant pull out my stock pulley maybe is too damn hard or idk.but i couldnt do it my selfso i decided to go to a mechanic and pay him to do it.but he couldnt take it out either and also the idiot was trying to pull it on the wrong way not clockwise,he even try to heat the bolt (idk is this is wrong to do )okay so im asking if someone knows a trick or something to take out my stock pulley and finally installed perrins pulley.my frs is manual.thanks in advance....
Sall is offline   Reply With Quote
Old 07-17-2012, 01:40 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i think your mechanic just fucked up your car mang
here is a subaru application, i can't imagine it being too different.
http://www.rs25.com/forums/f105/t113...ml#post1774930
Old 07-17-2012, 01:45 PM   #3
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
well my car has no issues and runs just fine.im thinking he just lock the bolt just even more..or in which way you think he fucked up my car ???
Old 07-17-2012, 01:46 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
did he blow-torche the crankshaft bolt until it was red hot?
Old 07-17-2012, 02:07 PM   #5
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
no he just heat it up alittle bit.is my first time changing a pulley i didnt thought it will be this difficult i have asked many mechanics and they all say they need to removed the front bumper and vents ......
Old 07-17-2012, 02:09 PM   #6
ahausheer
Re-member
Drives: Toyota camry
That mechanic sounds like an idiot.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-17-2012, 02:10 PM   #7
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
well tbh im more idiot for letting him do that ....i just hoped i can removed the bolt .
Old 07-17-2012, 02:11 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
take your car to a subaru shop, it looks like your mechanic doesn't know shit fuck all on how to work with boxer engines.
Old 07-17-2012, 02:16 PM   #9
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
thanks man.its just that ive seen a few people here saying they took 10min to install and tought this shit is simple to do ,i guess not.
Old 07-17-2012, 02:23 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it is simple if you use the right tools and know how to use them.
Old 07-17-2012, 02:33 PM   #11
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
is there someone in socal that has installed this please let me know thanks...
Old 07-17-2012, 02:39 PM   #12
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
Have you called Perrin for advice?
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 07-17-2012, 02:39 PM   #13
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Heating the bolt? That's the opposite of what he'd need to do.
Just need to pick up a pulley tool that will keep the pulley from rotating while leaning on it with a breaker bar.
I was able to remove mine by putting car in 5th gear and cranking on the hand brake as hard as I could. That bolt is seriously on there!
cobrabyte is offline   Reply With Quote
Old 07-17-2012, 02:40 PM   #14
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
I ended up using my torque wrench to get it loose. It was the only wrench long enough to get the necessary leverage on the bolt.
I bet it had over 125 lbs of torque on it from the factory.
Starscream15 is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
BRZ LED lights installed KI_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 24 07-04-2012 05:34 PM
