Old 06-01-2017, 11:13 PM   #1
bryanjuz94
Drives: 2014 Subaru BRZ
Fuel pump will not Prime?
I got finished a installing a new motor a few weeks ago went to start it this weekend when I noticed the fuel pump will not prime unless power is connected directly to it. Even once the pump is connected the car cranks very slowly but wont start. I tried replacing the relay and check all the grounds and even changed the battery still no luck. Any ideas?
https://drive.google.com/open?id=0Bz...1ZBYTVYdXQwQWc - Errors/codes that are showing on Motec
https://drive.google.com/open?id=0Bz...TNmQ2VwNTFvNDA
https://drive.google.com/openid=0Bz3...U9pa1lacWpCdVE
https://drive.google.com/open?id=0Bz...kRYYkNkdkFGZDA
https://drive.google.com/open?id=0Bz...XZpT1cyZHFMYjA
bryanjuz94 is offline   Reply With Quote
Old 06-01-2017, 11:35 PM   #2
Loose hose/fitting sucking air someplace? Connecting directly may be bypassing a relay or sensor that won't let it pump unless there is fuel pressure and although you are forcing it to pump it is still sucking some air preventing the proper build up in the rails.
Wild guess but I have had fuel pumps that would not draw due to air leaks before.
Old 06-01-2017, 11:55 PM   #3
humfrz
Which fuel pump are you talking about ...... the one in the gas tank or the HPFP ....??
humfrz
Old 06-02-2017, 12:06 AM   #4
bryanjuz94
humfrz
Gas tank
Old 06-02-2017, 12:36 AM   #5
humfrz
Originally Posted by bryanjuz94 View Post
Gas tank
hmmm.......have you taken the pump out and inspected/tested it .. ??
Under a normal connection, is power getting to the pump..??
humfrz
Old 06-02-2017, 01:54 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
He said it runs when he connects to it directly.
What's the deal with the motec? Were you running with it before you swapped the engine?
Old 06-02-2017, 08:23 AM   #7
bryanjuz94
The motec was installed on the car with the old motor.
Old 06-02-2017, 09:10 AM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You're running the Motec for an FA20? The previous motor was also an FA20? The car ran perfect before with the Motec?
There is a pump "controller" that the Motec would need to control in order for the in tank fuel pump to work. The package provided by Pure Automotive for 2JZ/LSx swaps provides the connections and software to control the OEM pump "controller". Other ECU swap solutions do not provide for using the OEM pump controller, so people need to bypass that controller in order to be able to use the OEM pump. Just a thought.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
FRSBRZGT86FAN (03-22-2018)
Old 06-02-2017, 09:28 AM   #9
bryanjuz94
I am running a plug n play motec for fa20. Old motor was fa20 and new motor is also fa20. Car ran fine before with the motec.
The Following User Says Thank You to bryanjuz94 For This Useful Post:
Sportsguy83 (06-02-2017)
Old 06-02-2017, 09:31 AM   #10
Sportsguy83
Drives: Limited BRZ
You're going to probably need to try and trace the cable for continuity, maybe the cable got torn/cut somewhere along the way while replacing the motor?
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
FRSBRZGT86FAN (03-22-2018), Ultramaroon (06-02-2017)
Old 06-02-2017, 01:51 PM   #11
Ultramaroon
not playing cards
Yeah, Bryan, I'm thinking the same thing. Refer to the OEM wiring diagrams. You're lucky those apply with the P&P unit.
Old 03-12-2018, 06:42 PM   #12
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
AHHHHH!!! I AM HAVING THE EXACT SAME PROBLEM. Motec M150 PnP FA20. Car ran great during tuning the new built motor. Get home and it dies. Motec shows the same fuel pump off voltage. Pump checks out fine with 12v+ but will not prime with ignition on or during cranking. Im pulling my hair.
xkalelx is offline   Reply With Quote
Old 03-12-2018, 06:43 PM   #13
xkalelx
xkalelx's Avatar
Did you ever find the smoking gun? Please say yes.
Old 03-20-2018, 04:03 PM   #14
xkalelx
xkalelx's Avatar
Found my issue. It was the DI controller not grounding properly to the motor.
The Following 3 Users Say Thank You to xkalelx For This Useful Post:
humfrz (03-20-2018), Sportsguy83 (03-20-2018), Tcoat (03-20-2018)
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 07:39 AM
Prime Motoring Flex Fuel Kit V2 Nhan55nguyen Engine, Exhaust, Bolt-Ons 2 06-05-2016 01:58 PM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 07:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
