Drives: 2017 WRB Subaru BRZ
LEGIT: Electric Compressor + larger Turbocharger Borg Warner released last month
LEGIT: electric supercharger mated to larger turbocharger from BorgWarner...
in 2016 BW's R&D department put out this video of what their team was working on, but just last month they had the below press release that they are really REALLY in mass production for this technology now!!!!! Twin-charging isn't new but using an electric centrifugal compressor(supercharger) is revolutionary and it will save you fuel and pollute less. [ame="https://www.youtube.com/watch?v=eXWAPNOAuv0"]eBooster® Electrically Driven Compressor - YouTube[/ame] https://www.borgwarner.com/en/news-m...rates-premiere |
| The Following User Says Thank You to SStratos For This Useful Post: | swarb (06-01-2017) |
Time Traveller
This looks to be an OEM product. I didn't see anything that pointed to the aftermarket.
If it is aftermarket, then great! A mass produced version of the Phantom ESC in a twin charge configuration. If OEM, then we'll have to wait for mfgs to choose whether to use them or not. |
#3 | |
Correct me if I'm wrong but I think Borg Warner usually makes all of it's products accessible, to at the very least, it's licensed dealers/mechanics licensed to purchase and install their systems. ATM there may not be enough production currently to supply more than the OEM suppliers, but that will change in time. I just purchased my 2017 last November so I'm in no hurry to FI my car just yet. Going to do breaks and suspension and bushings first. |
#4 | |
Time Traveller
https://www.borgwarner.com/en/aftermarket I would be surprised if this device was offered to the aftermarket simply because of the additional electronics needed for throttle, and battery management (charge/recharge) to power a 48 volt device, but who knows? Also, tuning for this will take some work, but is obviously viable. Between what we have now and full E.V.s, electric super/turbocharging is definitely a viable solution. I've been running my non sequential 24 volt setup for over 2 years now and love it. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | SStratos (06-12-2017) |
FR Noob
It may improve the "turbo lag" but now there are more parts to to break.. I guess simplicity and power doesn't mix.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
#6 | |
| The Following User Says Thank You to swarb For This Useful Post: | avishenoy1 (06-02-2017) |
#7 | |
FR Noob
#9 | |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
No it really wont.
Nope sorry not revolutionary at all, won't save fuel and won't pollute less. I had an electric supercharger on my 2004 evo 8 back in 2004-2005. ![]() It was created and to act as a device to help the low end tq and help pre-spool the turbo. It was on my car while it had the factory turbo and an AVO turbo kit that made use of a turbo in the GT30 family. The electric turbo was a huge paper weight. It did very little to pre-spool the gt30 or factory evo turbo and would easily get drowned out one the main turbo started to come online. Gas mileage didn't improve. Anyone that is familiar with tuning knows that spooling/adding more air = gas is needed. So even with a low positive psi the engine is having air added into it (getting lean) and more fuel is needed to counteract the leaning effect of adding more air. Since you are adding more gas due to more air you technically are doing the opposite of not polluting. :-P lol It's funny that people are still attempting this. By the time I started getting active in the evo community shiv/vishnu was toning down his presence in that community but I figured he would have been aware of my car and its electric supercharger days. From one evo OG to another I was really surprised to see him revisit this idea as it didn't go down to well back in the day. If you want faster spool all of these does a better job: Anti-lag Timing changes Timing changes with respect to your (no lift shift) settings Cams Larger throttle body Larger intake manifold More displacement -the previous 4 hint at better air flow in the system -more air in = more exhaust gas to spin turbine = earlier spooling -earlier denser air introduced in the system is the idea the E-turbo is based on in its relation to pre-spooling. Though I must add that electric motor and battery technology has improved in the past 14 years. But in relation to a car like the evo or brz you are still limited by battery/recharging options. At the moment the best application for an E-turbo would be in a hybrid car. The E-turbo would benefit from the larger electrical potential those cars due to their batteries and recharge rates. Imagine if one to electric hub components which spins the wheels on a koenigsegg regara or mclaren p1 was focused into a spinning turbine application... it would prove to be a fun little hybrid hack to play with. (think civic hybrid with an electric powered gt35 intake wheel shoved into the intake system. You could literally flip a switch to go from turbo lag save my drivetrain characteristics to supercharger 100% on all the time beast mode characteristics. |
#10 |
mmm electric twincharger.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#11 | |
Time Traveller
| The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | TachyonBomb (06-02-2017), WRBrzRX (06-02-2017) |
#12 |
Drives: frs
Sounds like hybrid, high end cars have the same idea but with electric engine for low end and gas engine later. Wish they produce a nice E-sc with more boost, 8-10 psi would be tempting
#13 | |
Road-hole
Drives: 2013 Whiteout FR-S
Looked to me
It looked to me like the electronics were built in and were basically based on boost from the primary compressor. Jaden |
#14 | |
Drives: runs&drives
| 5% OFF all Borg Warner Turbos! | BRZFRSSTORE | Forced Induction | 0 | 02-23-2017 01:34 PM |
| First ever FR-S Borg Warner 7670 EFR turbo by JDL | texasbound972 | Forced Induction | 0 | 10-29-2014 11:19 PM |
| Borg Warner S255-RS .48 | FAER | Forced Induction | 39 | 05-16-2014 01:27 PM |
| Borg Warner Vs Garrett | DeBiase | Forced Induction | 12 | 12-02-2013 11:17 PM |
| Borg Warner Match Bot | diss7 | Forced Induction | 15 | 09-28-2013 10:13 AM |
