Old 05-30-2017, 03:39 PM   #1
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
FS: PTUNING 4-1 Equal Length Header
I recently parted out my FR-S and am selling my lightly used PTUNING header, I ran this with the PTUNING turbo kit and had excellent results. Header is in great shape and has some nice color to it.
$800 Shipped SOLD
- Custom spec 1/2" thick CNC T304 SS head flanges with back cut gasket face for better exhaust port gasket sealing.
- Custom spec 1/2" thick CNC T304 SS 2-bolt overpipe inlet flange.
- T304 SS v-band near merge collector for possible future upgrades to a full v-band header back exhaust system.
- Runner lengths designed around the offset cylinder 1 and 4 exhaust ports on the FA20 cylinder head.
- All 4 runners lengths are within 1.5% of each other from the back side of the exhaust valves to the merge collector.
- Rotational firing order into the 4-1 merge collector. Only one of it's kind for the FA20.
- Double-Slip 4-1 merge collector with custom spring tabs to allow for proper heat expansion without the need for flex bellows. Only one of it's kind for the FA20.
- Minimal exhaust runner up sweep at the front of the engine ensures that radiant heat is kept to a minimum. This also makes this header SC friendly.
- Low profile design allows the factory metal under tray to bolt back into place without any modifications or spacers.
- Each mandrel bent exhaust runner is constructed using the fewest number of sections possible. This ensures perfect exhaust flow as well as eliminating the need for extra weld joints.
- All six exhaust port studs are readily accessible to allow for ease of installation as well as the ability to properly torque down each nut.
- O2 sensor bung placement does not require extending the O2 harnesses.
skylinekin is offline
Old 06-06-2017, 07:26 PM   #2
skylinekin
skylinekin's Avatar
Bump!
Old 06-07-2017, 06:52 PM   #3
BertoFT
Drives: 13 FRS Firestorm
Edit: zoink
BertoFT is offline
Old 06-14-2017, 12:39 PM   #4
skylinekin
skylinekin's Avatar
SOLD
FS: PTUNING 304SS Equal-Length Competition Header shdobxr Engine, Exhaust, Bolt-Ons 26 04-16-2017 11:49 AM
PTUNING Equal-Length Competition Header RJasonKlein Engine, Exhaust, Bolt-Ons 5 07-07-2016 12:43 AM
*BRZ Part Out* PTuning equal length header xDanger_208x Engine, Exhaust, Bolt-Ons 2 03-31-2015 01:43 AM
