Old 05-19-2017, 12:42 PM   #1
extrashaky
Drives: 2014 BRZ Limited
Deeper closer steering wheel
I want a steering wheel that looks OEM-ish and retains the OEM airbag but relocates the rim of the wheel closer to me, preferably by about an inch. None of the product pages for aftermarket wheels seem to provide any info on how deep the wheel is. I would also prefer not to see any carbon fiber trim on it. Does anybody know of a wheel that meets these criteria?
Yes, I searched. There's a lot of noise on the board around steering wheels, and I didn't find what I was looking for. I also Googled and searched reviews on YouTube. It seems like the goal for many of the aftermarket steering wheels is to make them as douchey as possible without any consideration for steering position.
To be clear, I'm not interested in steering spacers or wheels that don't use the airbag.
Suggestions?
Old 05-19-2017, 01:09 PM   #2
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Nothing like this exists to my knowledge. I've been looking since I first bought the car in 2013...
Even the most "subtle" options include non-removable carbon fiber, which, frankly, is tacky as hell.
sdemo is offline   Reply With Quote
Old 05-19-2017, 01:49 PM   #3
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
If you ever find one let me know. I ended up getting a Sparco wheel and getting rid of the airbag. The suede wheel is awesome but I would have loved to be able to keep the airbag and just have the wheel a bit closer.
If you end up getting an aftermarket setup get the quick release to move the wheel a bit closer and get something with a nice deep dish. The steering wheel adjustment in this car is not very friendly if you have the seat all the way scooted back.
sirbobbinhood is offline   Reply With Quote
Old 05-19-2017, 02:49 PM   #4
extrashaky
What got me started looking this morning is a post in the classified section for a very nice ATC steering wheel that is deeper than stock but has carbon fiber accents. I can't seem to located an ATC wheel that doesn't have that stupid carbon fiber.
I did find a KEY!S steering wheel that would be almost perfect except for the exceedingly douchey print emblazoned across the top. There's no way I'm putting that in my car.
So back I go to the search. I may end up buying one of these carbon fiber wheels and having a local upholstery shop cover the douchey bits in leather.
That's just it, I want to keep an OEM-ish look and retain the airbag. If I didn't mind losing the airbag, I would have plenty of options.
I think this car was designed around a Japanese body. Of course not all Japanese people are built the same way, but years ago when I trained in Japanese martial arts most of our Japanese members had average length torsos and arms but shorter legs (by American standards). With that kind of build, you'd fit in this car almost perfectly by scooting the seat up. If you have longer legs on the same kind of torso, sliding the seat back to fit your legs puts the steering wheel out of reach.
Old 05-19-2017, 03:16 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
I've been halfheartedly scheming for a way to modify the telescoping column since I've owned mine. I'd love to extend it another 4-6 inches safely.
Yes, I understand all the ramifications. Sure would be nice, though.
Bring on the penis jokes.
Old 05-19-2017, 03:24 PM   #6
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 05-19-2017, 03:33 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
There are also three other wheels by using same base as Key!s, J Luth ones. #1, #2, #3
Last one seems least ricey. Ideally i'd have Key's silvery plastic bits + black wheel from last url, as carbon looks also scream rice, but there seems to be no such customizing option.
These four are only ones i know to be 20mm closer to driver & still allowing to use stock airbag. No "spacer" AFAIK exists. And probably these won't do for MY2017 due not letting reuse steering wheel controls on those.
Hmm, except getting steering wheel closer there is also option of lowering seat base (some velding/cutting seat cushion involved). That should allow put seat's back more straight, lessening need to move seat too much front to reach steering wheel close enough.
Old 05-19-2017, 04:01 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Something like this but with an airbag?
Old 05-19-2017, 04:04 PM   #9
sdemo
sdemo's Avatar
I'm looking into this to move the seat further back without sacrificing wheel position. What a dream that seems to be... my only nagging issue with the car.
To a previous point, my vietnamese friend with a BRZ has the seat far enough up that he doesn't even use the console armrest.
Old 05-19-2017, 04:09 PM   #10
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Velding!
VIP BRZ is offline   Reply With Quote
Old 05-19-2017, 04:26 PM   #11
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
http://www.ft86club.com/forums/showthread.php?t=117897
This one sold but there's a link to buy new.
ApexEight is offline   Reply With Quote
Old 05-19-2017, 04:41 PM   #12
sdemo
sdemo's Avatar
^ non removable carbon fiber
Old 05-19-2017, 05:26 PM   #13
extrashaky
I feel silly typing KEY!S. From now on I'm just going to call it Keys instead. Stupid Japanese misuse of English punctuation.
There are also three other wheels by using same base as Key!s, J Luth ones. #1, #2, #3...
The ATC wheels appear to also use the exact same frame, and in fact I found a write up about the Keys wheel that said it was developed with ATC. It looks like it might just be an ATC wheel with a difference cover and different plastic bits.
This has me wondering how difficult it would be to remove the plastic parts from these wheels. I wonder if I could get an ATC wheel and a Keys wheel and swap the carbon for the silver plastic, which looks like it would match my trim. Then I could put the Keys wheel on the member classified board as a Super One-of-a-Kind Custom Steering Wheel to recoup some of my money.
That's the one that started me looking for a new wheel, because it was almost what I wanted but with douchey carbon fiber. You'll notice I actually posted in that thread to ask what he used to replace it, since I was hoping maybe he had found another less douchey alternative.
Old 05-19-2017, 05:36 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
extrashaky: Hmm. I checked up right now on ATC wheels just after writing that post. It seems that J-Luth & ATC Sport wheels are 1:1. Same three wheels of same three finish types. All with carbon inserts, one with carbon top, one all black leather, one black with red leather on top. Prior finding out about ATC-s, it seemed that J Luth was original source.
Anyway, what i'm thinking of right now, is getting all-black leather one by J Luth or ATC & wrap those inserts into something less ricy. Or painting. Wrapping might not hold well for long for something that is touched with hands all the time, no?
There is also alternative getting Key!s & rewrap wheel, not inserts, with some normal leather or alike.
SOLD: ATC steering wheel ( smaller diameter+offset closer to the driver) toeout Interior Parts (Incl. Lighting) 7 05-19-2017 02:15 PM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Possible to extend steering wheel closer to the driver? swarb Cosmetic Modification (Interior/Exterior/Lighting) 24 07-22-2015 03:04 PM
