Drives: 2014 White BRZ
Radium dual Catch Can - FI Install
I have done some search and reading and I am a little confused.
Do the dual catch can get installed the same on a turbo application vs NA? One can in series with the PCV and one in series with the CCV. (I know VTA is another option however I am referring to closed loop) Some have indicated a check valve is required on the PCV side. I am preparing to a Turbo install and want to make sure I understand ahead of time. Thanks |
#2 | |
I Love custom Turbo kits
Drives: Limited BRZ
When the time comes I was going to follow the radium instructions which basically has u disconnect the breather line from the intake tube and connect the inlet to the can to the breather tube and the outlet to the intake. Only difference is I'll connect to the intake tube before the turbo inlet.
#4 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | randomthoughts (05-19-2017) |
| The Following User Says Thank You to randomthoughts For This Useful Post: | Sportsguy83 (05-19-2017) |
Drives: BRZ Turbo
Hi everyone, sorry to bring up an old post but this is the exact same question I have however I am a little bit dumber.
Can someone explain to me why you need a check valve after the PCV to the catch can? I have just ordered the dual system, and I have a boosted BRZ. I have the Tradstone kit. My kit looks similar to this, with a barb on the intake where I have circled as well: blob:https://imgur.com/566222bc-c4af-4d67-988e-dfecba91a962 Is there a turbo guide for the Radium set? Is it the same install instructions except for adding a valve check? Thanks in advance. |
It's not really from the PCV to the catch can, it's from the intake manifold side to the catch can. Obviously with turbo the IM is pressurized and you don't want to pressurize either the catch can or the crankcase.
#8 | |
Drives: BRZ Turbo
I also noticed in the Radium description it says it can handle pressure? I am unable to find a guide for installing with a check valve it where to put it, however am now very confused with the mixed answers. Edit: in the product description it says “Note: Because the Radium catch cans are pressure sealed, they are great for boosted applications as well so connecting to the intake manifold is permitted. ” Last edited by thinkV; 08-21-2018 at 08:08 PM. |
Well if they are doing special to restrict pressure from going into the IM connection, I guess you could take their word for it. Otherwise a check valve isn't all that expensive.
#10 |
Drives: Q5 + BRZ + M796
Why not just add a check valve? It couldn’t hurt anything
| Radium Dual Catch Cans on NA setup | xstatic | Engine, Exhaust, Transmission | 7 | 05-14-2017 12:31 PM |
| Radium dual oil catch can kit | Bluetail | Engine, Exhaust, Bolt-Ons | 0 | 07-11-2016 10:19 PM |
| FOUND: Radium Dual Oil Catch Can Kit | asnatlas | Want-To-Buy Requests | 1 | 05-20-2016 11:06 PM |
| Radium Dual Catch Can Kits With AVO Turbo Kit | tonytduc | Forced Induction | 1 | 01-11-2016 03:10 PM |
| Radium Dual Catch Cans with AVO kit & RHD | Skorov | Forced Induction | 6 | 04-08-2015 11:22 PM |
