Old 05-18-2017, 09:53 PM   #1
randomthoughts
Drives: 2014 White BRZ
Radium dual Catch Can - FI Install
I have done some search and reading and I am a little confused.
Do the dual catch can get installed the same on a turbo application vs NA?
One can in series with the PCV and one in series with the CCV. (I know VTA is another option however I am referring to closed loop)
Some have indicated a check valve is required on the PCV side.
I am preparing to a Turbo install and want to make sure I understand ahead of time.
Thanks
randomthoughts is offline   Reply With Quote
Old 05-19-2017, 07:53 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks
Yes it's the same routing, yes you need a check valve on the PCV. I THINK you'd also need a check valve on the breather side. What location are you plumbing back the breather side into the intake?
Old 05-19-2017, 11:14 AM   #3
randomthoughts
When the time comes I was going to follow the radium instructions which basically has u disconnect the breather line from the intake tube and connect the inlet to the can to the breather tube and the outlet to the intake. Only difference is I'll connect to the intake tube before the turbo inlet.
Old 05-19-2017, 11:16 AM   #4
Sportsguy83
Drives: Limited BRZ
Ok, if it's going to be pre-turbo you do not need a check valve on the breather.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
randomthoughts (05-19-2017)
Old 05-19-2017, 01:15 PM   #5
randomthoughts
Ok thanks. That clears things up for me
The Following User Says Thank You to randomthoughts For This Useful Post:
Sportsguy83 (05-19-2017)
Old 08-21-2018, 05:28 AM   #6
thinkV
Drives: BRZ Turbo
Hi everyone, sorry to bring up an old post but this is the exact same question I have however I am a little bit dumber.
Can someone explain to me why you need a check valve after the PCV to the catch can?
I have just ordered the dual system, and I have a boosted BRZ. I have the Tradstone kit.
My kit looks similar to this, with a barb on the intake where I have circled as well:
blob:https://imgur.com/566222bc-c4af-4d67-988e-dfecba91a962
Is there a turbo guide for the Radium set? Is it the same install instructions except for adding a valve check?
Thanks in advance.
thinkV is offline   Reply With Quote
Old 08-21-2018, 01:58 PM   #7
xwd
It's not really from the PCV to the catch can, it's from the intake manifold side to the catch can. Obviously with turbo the IM is pressurized and you don't want to pressurize either the catch can or the crankcase.
Old 08-21-2018, 05:39 PM   #8
thinkV
Drives: BRZ Turbo
So i emailed Radium when I posted this and hey said it is not required?
I also noticed in the Radium description it says it can handle pressure? I am unable to find a guide for installing with a check valve it where to put it, however am now very confused with the mixed answers.
Edit: in the product description it says “Note: Because the Radium catch cans are pressure sealed, they are great for boosted applications as well so connecting to the intake manifold is permitted.
Old 08-21-2018, 09:42 PM   #9
xwd
Well if they are doing special to restrict pressure from going into the IM connection, I guess you could take their word for it. Otherwise a check valve isn't all that expensive.
Old 08-22-2018, 09:33 AM   #10
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Why not just add a check valve? It couldn’t hurt anything
Radium Dual Catch Cans on NA setup xstatic Engine, Exhaust, Transmission 7 05-14-2017 12:31 PM
Radium dual oil catch can kit Bluetail Engine, Exhaust, Bolt-Ons 0 07-11-2016 10:19 PM
FOUND: Radium Dual Oil Catch Can Kit asnatlas Want-To-Buy Requests 1 05-20-2016 11:06 PM
Radium Dual Catch Can Kits With AVO Turbo Kit tonytduc Forced Induction 1 01-11-2016 03:10 PM
Radium Dual Catch Cans with AVO kit & RHD Skorov Forced Induction 6 04-08-2015 11:22 PM
