Old 05-17-2017, 08:43 AM   #1
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Part number for window switch connector terminal?
I'm trying to retrofit a USDM passenger door lock/window switch to my 2013 86 because mine doesn't have the door lock/unlock button. I already have the USDM switch panel and it's plug and play with my harness. I've studied the wiring diagram and I only need to hook up pins 15 and 16 on my passenger switch connector to the wires on the same pins on the driver side. I need the female terminals that will slide into the empty terminals on my passenger switch socket. Anyone know the part number or an aftermarket source for those pins?
HRTROB is offline   Reply With Quote
Old 11-13-2022, 06:06 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Bump. Also looking for this info regarding the female wire terminals for power window switch
Even a trade name or specification insights would be helpful
It doesn't seem to be a standard Toyota or Subaru connector, so it doesn't show up on connector diagrams. However, it's a somewhat common connector and used on window switches for other Subarus and Japanese auto makes
EndlessAzure is offline   Reply With Quote
Old 11-13-2022, 10:05 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would recommend contacting a junk yard and getting them to cut off the harness from a wrecked model.
Old 11-15-2022, 07:47 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
This looks a lot like it but I'm having difficulty getting a real part number for the connector.
https://www.amazon.com/Assembly-Conn...dp/B08BJ3WX2D/
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 02-25-2023, 07:25 PM   #5
Ace23_BRZ
Ace23_BRZ's Avatar
Drives: 2013 Subaru BRZ
It's a Furukawa Caselanceless Standard・NS-LC type, NS16FW-LC, PK415-16017.
Ace23_BRZ is offline   Reply With Quote
Old 02-27-2023, 07:44 AM   #6
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
#Legend
Part number for fusible link block on positive battery terminal? Jack Black Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-24-2022 08:58 AM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 12:05 AM
Part # Needed Cluster Surround & Window Switch Covers Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 6 12-25-2013 11:19 AM
Part number request for heated seat switch trim azian_advanced Cosmetic Modification (Interior/Exterior/Lighting) 1 09-13-2013 11:02 PM
USB (IPOD) Dash Connector Part Number Question SilentMike Cosmetic Modification (Interior/Exterior/Lighting) 0 07-14-2013 04:29 PM
