Old 05-14-2017, 02:19 AM   #1
_shnxfrs
Replacement Part
Anyone know where I can get another connector like this, sorry I have no idea what this is called.
http://i.imgur.com/GG1cCEZ.jpg
_shnxfrs is offline   Reply With Quote
Old 05-14-2017, 09:51 AM   #2
stevesnj
stevesnj's Avatar
http://www.mouser.com/Connectors/Aut...tors/_/N-1ehb5
My 2016 Build thread
Old 05-15-2017, 12:33 PM   #3
stevesnj
stevesnj's Avatar
Found the site, I buy connectors for my old Landcruiser here. You will have to search around but they should have it. You can email them a pic of the connector you need and they should be able to match that way too
https://www.bmotorsports.com/shop/index.php/cPath/109
Old 05-15-2017, 01:39 PM   #4
markitect
Drives: Scion FRS
Also the connector should have the part number on it, it's molded in. A dry erease marker can help make it visible.
markitect is offline   Reply With Quote
Old 05-15-2017, 03:22 PM   #5
stevesnj
stevesnj's Avatar
True, I think it's a letter number configuration. The color is also specific for inside the car. The Electric Diagram for this car should have the connector name on it. I just don't have it in front of me
Old 05-15-2017, 10:42 PM   #6
_shnxfrs
Oh okay, just got home and took a look at it, I see something like >PBT< 12361
Old 05-16-2017, 08:59 PM   #7
stevesnj
stevesnj's Avatar
This it?
http://minkara.carview.co.jp/userid/...137/parts.aspx
Old 05-18-2017, 01:39 PM   #8
_shnxfrs
Yeah thats exactly it ! Thank you so much!
Old 05-23-2017, 08:39 PM   #9
_shnxfrs
I have another issue, I just got the housing connector, but now it doesn't have the metal thing that's inside, by chance do you guys know what thats called and where to get it?
Old 05-23-2017, 11:01 PM   #10
darko
Drives: RAVEN FRS
http://ca.mouser.com/Connectors/Pin-...tors/_/N-ay0mm
darko is offline   Reply With Quote
Old 06-01-2017, 09:35 AM   #11
markitect
Drives: Scion FRS
Check Out: http://www.ft86club.com/forums/showthread.php?t=102947 There is a table near the end that tells you what type of terminal each housing takes. You need 0.64 II Female unsealed. There will be several options on mouser or digikey, you can probably even find them on amazon; make sure to get one for the wire size you plan on using. Check out:
https://www.eficonnection.com/home/p...lated-terminal
Old 10-30-2017, 04:05 PM   #12
quindecima
Drives: GT86
You can also check here https://www.icrfq.com/category/10 there are too many connectors, I think you can find there exactly which connector you needed.
quindecima is offline   Reply With Quote
2013 BRZ replacement starter, correct part help sftateofmind Issues | Warranty | Recalls / TSB 25 07-21-2016 10:12 PM
DWL Front splitter fastener / hinge - replacement part? 1Cor10:23 Tracking / Autocross / HPDE / Drifting 0 07-04-2016 12:28 PM
Replacement Part assistance! Crackseed Hawaii 6 12-31-2014 03:49 PM
Lost a Taillight Nut; Part Number/Replacement? titleistforged Cosmetic Modification (Interior/Exterior/Lighting) 3 10-30-2014 05:55 PM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 12:05 AM
