Old 03-15-2016, 10:58 PM   #1
NahumCC
Drives: 2013 FR-S 10 Series
Toyota Wire Harness Repair Manual
Found this tonight and have loaded it to my google drive.
Use this link to access it and get part numbers for connectors on the car, part numbers for repair section of wire with terminal already crimped on, and the part number for sealing plugs needed where no wiring is required in a plug.
https://drive.google.com/file/d/0B6L...ew?usp=sharing
Please Sticky.
NahumCC is offline   Reply With Quote
The Following 3 Users Say Thank You to NahumCC For This Useful Post:
stevesnj (03-16-2016), that_one_guy (03-16-2016), zeal86 (03-15-2016)
Old 03-16-2016, 11:25 AM   #2
stevesnj
stevesnj's Avatar
Thanks, i do my own electrical work so this is helpful...
My 2016 Build thread
Old 02-23-2022, 02:45 AM   #3
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Hello,
Could you guys please advise me on an harness question
I have a 2013 GT86 A/T with a messed up engine harness (some single wires cut out connecting at random points probably by the previous owner) mechanic suggested to buy a new harness. Can I buy any Engine Harness from '13 - '20? Or are there more specifics?
I_amhassan is offline   Reply With Quote
Old 02-23-2022, 02:41 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by I_amhassan View Post
Hello,
I am not sure if there is anything additional for the AT but the 13-14' engine harness should be the same. 15-16" engine harness is different as the plug for the ignition coils was changed as were the coils. 17' and up is different again.
You can use a 15-16' harness on an older car, but you will need to change the ignition coils to the newer style.
Old 02-24-2022, 06:52 PM   #5
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
That is so much helpful! Thank you so much!
Old 04-12-2022, 02:42 PM   #6
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
One more question guys can anyone confirm if the subaru and toyota harnesses are same?
Toyota Part number: SU00304463
Subaru Part number: 24020AG080
Or any confirmation that i can use the subaru harness on my toyota 86
Old 04-13-2022, 01:40 AM   #7
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Couldn't access your drive. I requested.
But anyways, I'm sure it'll be helpful.
What I noticed on other older platforms that never had repair manuals and wiring diagrams online (like my mk3 supra), it has been immensely helpful that a few folks grabbed scans and uploaded repair manuals and wiring to the internets.
May not be as much of an issue with the twins since they are much newer and probably on TIS, but it always helps to have this stuff accessible to enthusiasts.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Tweeter Wire Harness Lambo_FR-S Electronics | Audio | NAV | Infotainment 4 06-13-2018 10:08 PM
Help: Sidemarker wire harness connector It's Jay Electronics | Audio | NAV | Infotainment 0 06-27-2015 11:51 PM
Wire Harness SergeLo01 Scion FR-S / Toyota 86 GT86 General Forum 1 07-17-2014 08:06 PM
MAF sensor wire harness SavingManuals Engine, Exhaust, Transmission 0 05-30-2014 09:20 AM
free wire harness on passenger side is for? SuperDave BRZ First-Gen (2012+) — General Topics 7 08-21-2012 02:12 PM
