Old 05-11-2017, 03:52 AM   #1
mybrzisslow
Drives: 2016 WRB Subaru BRZ
Need advice grounding DDX916ws HU
Simply put, I have a DDX916WS head unit along with a 28pin harness that I purchased from Auto Harness House. This is all going into a 2016 BRZ.
The 28pin harness allows me to retain all OEM functionality of the reverse camera, Aux, etc.
Now I know what few wires I need connect and splice together, except I am unsure about the two ground wires that belong to the 28pin harness; I have dark green wire that is for grounding the reverse camera, and a thicker black grounding wire.
My questions are; Is it necessary to ground these wires? If so, which of the two should I splice into the head unit's grounding wire?
Also here is a photo of the 28 pin harness I am using;
Last edited by mybrzisslow; 05-11-2017 at 03:53 AM. Reason: Adding photo of harness
mybrzisslow is offline   Reply With Quote
Old 05-11-2017, 12:30 PM   #2
Chimera
Drives: FRS
you can ground both to the OEM ground. Ground is ground is ground, except it isn't exactly with inductive loads, but that shouldn't be the case here.
there's a concept of poor or bad ground, where the ground could get busy or backed up. lookup ground loops, or inductive load dump if you want to know more, but its safe to ground both to the same spot. technically the whole car shares the frame as its common ground.
Old 05-11-2017, 03:53 PM   #3
mybrzisslow
So technically, I can connect the green "video ground" cable to the black ground cable, and then proceed to connect that black ground cable, to the chassis ground cable of the head unit's harness?
I also believe I need to connect the ebrake wire to the chassis ground cable as well in order to play video while driving.
Old 05-11-2017, 04:16 PM   #4
mybrzisslow
sorry for the noob questions. I have looked at a plethora of HU install vids, and DIY wiring topics here on the forum, but I wanted to make sure I do this right and not screw anything up.
Old 05-11-2017, 04:22 PM   #5
Chimera
Drives: FRS
Its fine, yes you should be able to ground them all together. the parking brake may need to be flashed, I know on pioneer units they need to see and on off cycle on ground, there are people on amazon that sell bypass relays. on kenwood I haven't personally encountered that before.
Old 05-11-2017, 08:02 PM   #6
Byza
Drives: 2017 86 GTS
Have you seen this video? It's specifically for the DDX916WS. If you are still unsure maybe flick carbon car sounds an email, they seem pretty helpful.
[ame="https://www.youtube.com/watch?v=3pl4z677Xq0"]DIY: How To Install A Stereo In Your Toyota 86 / Subaru BRZ - YouTube[/ame]
Byza is offline   Reply With Quote
Old 05-12-2017, 09:27 AM   #7
mybrzisslow
Yeah I've already seen that video. The problem is that they do not install the 28 pin harness adapter to retain the AUX and reverse camera. I needed to know how and where to ground the two grounding wires of this harness adapter.
Old 05-12-2017, 11:22 AM   #8
Chimera
Drives: FRS
How is the camera getting powered?
IF it is switched power from reverse lights or so, then ground it to the OEM ground. if its not switched power then the ground needs to be switched so the camera is not always on even when the car is off.
Old 05-12-2017, 06:16 PM   #9
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Here is your answer, go to one of these....
https://www.google.com/search?q=virg...utf-8&oe=utf-8
IceFyre13th is offline   Reply With Quote
Old 07-08-2017, 01:12 AM   #10
psionix
Drives: 2017 WRBP BRZ MT
Hi, I am in the same situation as you. Thinking of installing a ddx917ws to my 2017 BRZ.
I probably will be flying in the harness from CarbonCarSystems but I wish to retain the factory AUX as well.
Could you kindly guide me on how you did it?
psionix is offline   Reply With Quote
DDX916WS in 2013 BRZ Naeblis Electronics | Audio | NAV | Infotainment 11 04-11-2018 01:31 AM
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 11:47 AM
Headunit with the same fit as the Kenwood DDX916WS? l1512191 Electronics | Audio | NAV | Infotainment 5 07-19-2017 03:40 PM
3 Way component speakers, amp and DDX916WS Recoil6 Electronics | Audio | NAV | Infotainment 20 03-15-2017 10:12 PM
Installed my old grounding kit. Fish Electronics | Audio | NAV | Infotainment 4 06-02-2012 12:14 PM
