Drives: Ultramarine Blue FRS
Disable Rear O2
Keep getting P0140 CEL. Rear O2 No Voltage. I double checked the connector, everything looks fine. So I figure it's just shot.
I installed catless headers 5 months ago and have been running the OFT OTS Stage 2 UEL 91 oct tune since. About 15k miles. Gonna buy a new O2 sensor at some point, but can't right away, so I want to disable it. So from reading other threads I understand I need to 0 all inputs in the Closed Loop Fueling Target Compensation B (Load) in RomRaider. https://gyazo.com/0b54a6c17dda6a4e338f42fe068d25d7 So, I'm thinking I should 0 those, and then in the Primary Open Loop Fueling leaning out a bit around Idle to help compensate from running at 13.4 AFR like it has been. |
Set af#3 corrections to zero
Would that normally be in the Fueling - AF Corrections / Learning folder? Because I don't seem to have anything anywhere in my rom with AF#3.
https://gyazo.com/93ff4b63d8cdefbbbe55e3f109c72059 |
#4 | |
AF3 correction in my defs under Fueling AF correctiom /Learning try attached definition but check tables and make sure its matched to your rom Last edited by steve99; 05-11-2017 at 04:59 AM. |
Drives: Firestorm '13
Zero af3 tables then disable cel code for o2 voltage. I've been running with zeroed af3 tables for a year with no noticeable issues. Another thing if you intend to buy a new o2 sensor. Going catless might be why the o2 deteriorated prematurely. I bought a new o2 but left my bad o2 in for my catless header.
'13 Firestorm
| Tags |
| catless, header, oft, oxygen sensor, tune |
| TPMS Disable? | Newtothegrounds | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 03-30-2017 01:54 PM |
| How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 02:11 PM |
| how to disable drl ? | Ardenyo2k13 | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 05-03-2016 09:38 PM |
| Automatic VSC ABS TRC disable box | KenTK808 | Electronics | Audio | NAV | Infotainment | 0 | 04-04-2015 06:25 AM |
| Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 06:09 PM |
