Old 05-04-2017, 09:51 AM   #1
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
TOB #3 Lasts 2 Weeks
As the title says, I'm getting mildly annoyed with the throw out bearing issue.
  • Stock TOB lasted 3 years, lot's of track days motor was E85/header/Tune I was not having any TOB specific issues when the clutch failed.
  • Replaced clutch witch ACT 6 puck, car sat a while while motor was built but the TOB started squealing within a couple months of being back on the road.
  • Just had the TOB replaced along with a billet clutch fork and within 2 weeks the squeal is back. (Yes it goes away with just a slight touch of the clutch pedal)
Not having any issues other than the noise, it was professionally installed by a very experienced local shop and they will obviously install another under warranty. But..........any ideas what is going on and maybe it's just me but I seem to be reading a good many threads regarding these failures??
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 05-04-2017, 12:05 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I went through the exact same thing! My original TOB was squeaking and also make depressing the clutch harder. After my SC, I decided to change the clutch to the South Bend Clutch Stage 2. The TOB lasted a month before issues arose. The shop tried to say it was my velox clutch fork, but I just had them change the bearing. After 2 months it happened again. This time they changed the bearing, the input shaft, and reverted the fork to stock. No issues since. But I think the bearing comes down to being kinda lucky....
MS, CSCS, TSAC-F, CPT
Old 05-04-2017, 12:23 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Did your first or second replacement was a stock TOB? I've heard OEM TOB > ACT TOB, so if both of your replacements where ACT, that might be it.
$100 of new set of wheels or tires? Only lasts until wednesday bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-12-2014 09:09 AM
3 weeks without my BRZ :( exfortuna BRZ First-Gen (2012+) — General Topics 23 08-18-2014 12:58 PM
2 weeks from getting a brz tr1x5tuh Southern California 16 10-31-2013 10:27 PM
