Drives: Pearl 86
New beeping sound when I turn engine on or off
Is anyone familiar with this? After a drive, I turn off the engine and it beeps and a yellow key/car flashes a few times?
Asking because I've never had this happen when I got the car |
| The Following User Says Thank You to emishor86 For This Useful Post: | nextcar (05-03-2017) |
Drives: 2013 FR-S, 2023 BRZ
just a guess, maybe key battery is low?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
![]() 2023 Ignition Red BRZ 6MT awaiting boost ![]() |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
what's the manual say?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
Drives: Subaru BRZ
| The Following User Says Thank You to n0thing For This Useful Post: | funwheeldrive (05-03-2017) |
Drives: Pearl 86
Ah sweet. Is it hard to change out?
Drives: Toyota GT86 Coupe Red (UK)
Nope,run your nail (or a plastic knife) around the seem and pry it open. Take the battery to your favourite jewellers or if you can get the battery size identifier you could get one cheaper online.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
| The Following User Says Thank You to paulca For This Useful Post: | Teseo (05-03-2017) |
#7 | |
Drives: Subaru BRZ
no need to ruin your nails. simply remove the key blade, insert it into the horizontal slot then twist the keyfob housing apart. |
#8 | |
Drives: 2014 Scion FR-S Monogram
Changing the battery without prying your nail up is the best feature.OP do you by any chance have the door open when you turn it off? Mine beeps if I shut it off with the door already open.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
Drives: 2013 Scion FR-S Series 10
Yup, take out the key from the fob, then you will see a small rectangular indent. The head of the key fits into this. Push in and twist until the fob opens. You will see the battery beneath a cover. Flip the fob over and the circuit board should easily fall out, but you may need to pull because there might be glue or tape holding it in. You won't damage it.
Then you just need to push the small plastic tabs holding the battery - this can be a $#%#$%$# Can't remember what type of battery you need. It is a little larger than you typical watch battery. I think it is Battery CR2016 *PS I didn't change my battery for more than a month before replacing it, so you might be okay for a little while. I'll also note that both fobs died at the same time, even though the one never got used. So I had to replace them both at the same time. |
| The Following User Says Thank You to mazeroni For This Useful Post: | funwheeldrive (05-03-2017) |
| Engine will not turn off! | ShootZ | Issues | Warranty | Recalls / TSB | 44 | 12-08-2016 09:48 PM |
| Engine rattling sound like bogging the engine when not. | stockysnail | Engine, Exhaust, Transmission | 6 | 09-15-2016 12:57 PM |
| Rattle when i turn off the engine | Subforever | Issues | Warranty | Recalls / TSB | 11 | 08-18-2015 01:22 PM |
| Slight beeping sound while driving | Furinax | Issues | Warranty | Recalls / TSB | 2 | 10-31-2014 05:19 PM |
| car beeping after engine shuts off | mystic | Southern California | 10 | 04-14-2014 05:47 PM |
