Old 05-01-2017, 10:24 AM   #1
Traktor
Drives: Subaru BRZ Limited
Apexi Active Tail Silencer - Works!
Hello all,
I recently purchased a Type 1R Titanium Catback from a forum member for a decent price and combined it with the ACE-250 header and stock front pipe. I was hoping the stock front pipe would make it bearable in terms of noise, although the ACE headers are notorious for being quite loud when combined with any catback other than heavy catbacks like stock or something like an Invidia Q300. Noise levels are ok for the most part, however there was a bad low frequency resonance when under load between 2-3000RPM.
I then purchased an Apexi 90mm active tail silencer with a 100mm adapter to match the Type 1R exhaust tip. The silencer has a spring loaded valve that opens up when exhaust pressure reaches a threshold, so it is nice and quiet at low rpm, but wakes up at high RPM and is supposed to have minimal, if any hp loss. I would expect that it would not make a difference on my NA car.
I am happy to report that this has worked! The cold startup no longer sounds like a high powered subwoofer and the 2-3000RPM drone is gone, gone, gone! I am happy because if this couldn't be fixed then the stock catback was going back in. Can be removed by undoing one bolt for track days.
Traktor is offline   Reply With Quote
The Following 2 Users Say Thank You to Traktor For This Useful Post:
Hyper4mance2k (12-27-2017), StraightOuttaCanadaEh (12-20-2017)
Old 05-01-2017, 11:36 AM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
lame
VIP BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to VIP BRZ For This Useful Post:
churchx (12-20-2017), DAEMANO (05-01-2017), Teseo (05-01-2017), Turbo (06-17-2018)
Old 12-20-2017, 12:53 PM   #3
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Any idea how much the silencer weighs? I saw a shipping weight of 10lbs, which seems high.
Weigaldo is offline   Reply With Quote
Old 12-20-2017, 10:08 PM   #4
RJasonKlein
RJasonKlein's Avatar
This thread dates back to May, but as an aside the newer tunes from Delicious Tuning (I’m sure you’re using Delicious Tuning if you’re running the ACE header) are much quieter on cold start, along with offering a number of other benefits.
RJasonKlein is offline   Reply With Quote
Old 12-20-2017, 10:29 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
https://frsport.com/Active-Tail-Sile...bo_p_8062.html
About 10lbs
Old 12-27-2017, 10:17 PM   #6
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Awesome. I've been thinking about combining one of these with an HKS single exit. Still don't know how to make it fit the HKS 97mm tip, or if the tip is actually 97mm.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-17-2018, 08:11 PM   #7
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
I just installed the 115mm one on my Tomei 80r. There is a little bit of a gap. So I’m going to high temp rtv to seal it. I think the gab is too small for the adapter to fit. Other than that I like the sound better than the Tomei silencer.
sactownbwoy is offline   Reply With Quote
WTB>FRS invidia n1 silencer FR-Sky Want-To-Buy Requests 0 02-02-2016 02:06 AM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 Engine, Exhaust, Transmission 3 06-20-2014 01:04 PM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-19-2014 05:46 PM
TF Works tail light service pche Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 06:52 PM
4th of JULY - THANK YOU VETS & ACTIVE MILITARY FT86 OWNERS w/ TOM'S LED TAIL LI 468Power Exterior Parts - The Rest 2 07-05-2013 12:11 AM
