Old 05-01-2017, 03:38 AM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
FYI - no fuel cut on 2017 MT BRZ's (burnout content)
A friend of mine had thought that the new 2017 cars may have introduced a fuel cut "feature", when applying the brake pedal at the same time as the gas pedal. Much like a lot of cars have these days for safety reasons.
So, naturally I put the theory to the test, because why else would we be giving the car gas while braking? Well, brake stand burnouts of course FYI I did this with pedal dance mode on. Skip through to about 6:00 minute mark if you just want to see the smoke
[ame="https://www.youtube.com/watch?v=EXy8tiYJSuI"]BRZ burnout challenge part 2. Can a BRZ do a burnout? - YouTube[/ame]
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
Dark (05-01-2017), ~el~jefe~ (05-01-2017)
Old 05-01-2017, 11:23 AM   #2
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Ha. After I looked into it further, the BRZs have brake assist but not brake override.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
justinco (05-01-2017), ~el~jefe~ (05-01-2017)
Old 05-01-2017, 12:35 PM   #3
~el~jefe~
Drives: 2019 MX-5 RF
LOL! Pleasantly useless. Nice test.
~el~jefe~ is offline   Reply With Quote
The Following 2 Users Say Thank You to ~el~jefe~ For This Useful Post:
justinco (05-01-2017), trippinbillies40 (05-01-2017)
Old 05-01-2017, 12:38 PM   #4
bababooey
Drives: BRZ SWP Limited -6MT
that exhaust sounds great.
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
Old 05-01-2017, 01:20 PM   #5
imnotsureaboutbrz
Drives: between cars...
When you say 'pedal dance mode on' you mean you just used the 'off' button right?
imnotsureaboutbrz is offline   Reply With Quote
Old 05-01-2017, 01:24 PM   #6
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
No, I did the "pedal dance" combo of ebrake+brake pedal to disable everything.
Old 05-01-2017, 01:31 PM   #7
imnotsureaboutbrz
I was under the impression that on the 2017 cars when you held the Off button for a couple of seconds it disabled all the nannies?
see below...
http://i.imgur.com/fk9oNZ8.png
Old 05-01-2017, 02:01 PM   #8
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
see below...
I thought you have to hold down both buttons for mode 4? You are right though, you can achieve the same mode as pedal dance with the buttons.
On my old FRS, I did pedal dance because of the brake LSD interference. So, I just do it on the BRZ out of habit for stuff like this.
There was some rumors/chat on the older cars about pedal dance vs button disabling and how ABS changes with that. Never was able confirm.
I actually started using the both button disabling method for racing on the 17.
Old 05-01-2017, 02:20 PM   #9
imnotsureaboutbrz
Right so from a normal start you are in Mode 1. To get to:
Mode 2: Short press of the Off button
Mode 3: Press and hold (1 sec) "Track" Button
Mode 4: Press and Hold (3 sec) "Off" Button
And heres a confusing diagram to move between the modes.
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
tacos (05-01-2017)
Old 05-01-2017, 07:53 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What exhaust? All I heard was brostep.
Originally Posted by humfrz
I'm old and lazy
Old 05-01-2017, 08:24 PM   #11
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
hehe brostep
It's a Tanabe Concept G
If you want to hear more sound, I did that in another video. [ame="https://www.youtube.com/watch?v=MVzzv1HVDo0"]Tanabe Concept G exhaust install on 2017 BRZ[/ame]
Old 05-02-2017, 12:24 AM   #12
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I also read from a good source that they had a fuel cut feature. What sequence did you do exactly with the throttle/brake?
Because it's only when the throttle is already pressed, and then you apply brake. There is no fuel cut if the brakes are applied before the throttle (so heel-toe work).
But I'm guessing you pressed the brake after the throttle, so i'm puzzled
Maybe you need to go a certain speed for the fuel-cut to engage. Or have the nannies on. I'll have to test that.
nico_rsx is offline   Reply With Quote
Old 05-02-2017, 01:24 AM   #13
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I clutched dumped it at 7k rpms then moved my clutch foot to the brake. Maybe the fuel cut is silently disabled with pedal dance? You can test it out :p
Old 05-03-2017, 03:56 PM   #14
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
So what exactly does brake assist do? I know it does the brake LSD stuff and for traction/stability, is that it?
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 02:04 PM
Cost effecient (cheap) flex fuel kit to get up and running on E85 for 2017 BRZs? GNious Software Tuning 4 02-06-2017 06:22 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Delicious Tuning Flex Fuel for 2017+ Updated to Accommodate Manufacturer Revisions DeliciousTuning Software Tuning 0 01-04-2017 03:24 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
