Drives: '13 SWP GT86
Can someone educate me on rivnuts/nutserts etc
So I'm installing RB v1 fenders, and wanted to use rivet nuts so the fenders can be taken off, in case you need to, for whatever reason.
I got some from a friend who works as a mechanic, so didn't pay much attention to them, since they are M5-sized, which is what I need. The problem is, I've only done one front fender, and I've had four of them start spinning when trying to tighten the screws that hold the fender. I'm using a tool that another friend had, for rivets/rivnuts. Looks pretty much like so: ![]() The nuts are aluminium and have a grip range of 0.5-3mm. Do I need steel nuts? A different grip range? I have no idea. I can't see a way how they should be installed differently either, so not sure what to do here..
IG @squareddesign
http://www.squareddesign.se |
Drives: 2017 BRZ, Pure Red with PP
This may help
| The Following User Says Thank You to XK4 For This Useful Post: | sqd (04-30-2017) |
#3 | |
Drives:
This is the tool I have that has performed well for me: https://www.amazon.com/Astro-Pneumat.../dp/B01JBNA3RG __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | sqd (04-30-2017) |
#4 | |
IG @squareddesign
Drives:
Just like in the video link posted earlier... I don't have that fancy tool in the video though... I just file the notch in with a small file.
You can try to retighten the rive nut to increase the pull on the backing, sometimes a small burr or even paint will keep the nut from pulling all the way tight.
| The Following 2 Users Say Thank You to ls1ac For This Useful Post: | sqd (04-30-2017), Ultramaroon (04-30-2017) |
Tried that, but on at least one of them, the threads got ruined. These were pretty soft aluminium rivnuts to be honest. Going to try steel ones.
IG @squareddesign
Never use bare aluminum against bare steel. They will react and can corrode fast.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#10 |
#11 | |
But yeah, going to try steel ones.
IG @squareddesign
| The Following User Says Thank You to sqd For This Useful Post: | Tcoat (05-01-2017) |
#12 |
Excellent! I learned that lesson the hard way several decades ago.
#13 |
Drives:
This may be too much info... but just in case anynone is curious about this kind of thing... I figured I'd post it since Galvanic corrosion was brought up.
Table of Dissimilar Metals ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | Tcoat (05-02-2017) |
| Can someone educate me on warranty? | liquidimports | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-16-2013 03:48 PM |
| Can someone educate me about running E85 on this car and in general. | solidONE | Engine, Exhaust, Transmission | 16 | 04-09-2013 06:07 AM |
