Old 04-30-2017, 08:17 AM   #1
sqd
sqd's Avatar
Drives: '13 SWP GT86
Can someone educate me on rivnuts/nutserts etc
So I'm installing RB v1 fenders, and wanted to use rivet nuts so the fenders can be taken off, in case you need to, for whatever reason.
I got some from a friend who works as a mechanic, so didn't pay much attention to them, since they are M5-sized, which is what I need.
The problem is, I've only done one front fender, and I've had four of them start spinning when trying to tighten the screws that hold the fender. I'm using a tool that another friend had, for rivets/rivnuts. Looks pretty much like so:
The nuts are aluminium and have a grip range of 0.5-3mm.
Do I need steel nuts? A different grip range? I have no idea. I can't see a way how they should be installed differently either, so not sure what to do here..
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 04-30-2017, 08:30 AM   #2
XK4
XK4's Avatar
Drives: 2017 BRZ, Pure Red with PP
This may help
XK4 is offline   Reply With Quote
The Following User Says Thank You to XK4 For This Useful Post:
sqd (04-30-2017)
Old 04-30-2017, 11:32 AM   #3
zeal86
zeal86's Avatar
Drives:
That video is great... I just want to add that the keyed rivnuts are what you need. At my work we have both... the smaller rivnuts are mostly unkeyed. I think you'll be fine with aluminum rivnuts as long as they are keyed and you always make sure you are starting your screws/bolts straight.
This is the tool I have that has performed well for me:
https://www.amazon.com/Astro-Pneumat.../dp/B01JBNA3RG
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
sqd (04-30-2017)
Old 04-30-2017, 11:36 AM   #4
sqd
sqd's Avatar
Huh, hadn't heard about keyed rivnuts before.. Thanks for the info!
IG @squareddesign
Old 04-30-2017, 11:40 AM   #5
zeal86
zeal86's Avatar
Drives:
Just like in the video link posted earlier... I don't have that fancy tool in the video though... I just file the notch in with a small file.
sqd (04-30-2017)
Old 04-30-2017, 03:39 PM   #6
ls1ac
ls1ac's Avatar
You can try to retighten the rive nut to increase the pull on the backing, sometimes a small burr or even paint will keep the nut from pulling all the way tight.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
sqd (04-30-2017), Ultramaroon (04-30-2017)
Old 04-30-2017, 08:21 PM   #7
sqd
sqd's Avatar
Tried that, but on at least one of them, the threads got ruined. These were pretty soft aluminium rivnuts to be honest. Going to try steel ones.
IG @squareddesign
Old 04-30-2017, 10:48 PM   #8
Never use bare aluminum against bare steel. They will react and can corrode fast.
DAEMANO (05-01-2017), JD001 (05-01-2017), sqd (05-01-2017), Ultramaroon (04-30-2017)
Old 04-30-2017, 11:37 PM   #9
Gunman
Drives: 2019 Mazda Miata RF
Galvanic corrosion
The Following User Says Thank You to Gunman For This Useful Post:
Tcoat (05-01-2017)
Old 05-01-2017, 07:04 AM   #10
Originally Posted by Gunman View Post
Galvanic corrosion
Yeppers
Old 05-01-2017, 12:43 PM   #11
sqd
sqd's Avatar
No worries, I prepped the drilled holes with both rust primer and "underbody compound" (have no idea the English word for it) before installing the rivnuts.
But yeah, going to try steel ones.
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post:
Tcoat (05-01-2017)
Old 05-01-2017, 01:13 PM   #12
Excellent! I learned that lesson the hard way several decades ago.
Old 05-02-2017, 10:16 AM   #13
zeal86
zeal86's Avatar
Drives:
This may be too much info... but just in case anynone is curious about this kind of thing... I figured I'd post it since Galvanic corrosion was brought up.
Table of Dissimilar Metals
Tcoat (05-02-2017)
Can someone educate me on warranty? liquidimports Scion FR-S / Toyota 86 GT86 General Forum 5 09-16-2013 03:48 PM
Can someone educate me about running E85 on this car and in general. solidONE Engine, Exhaust, Transmission 16 04-09-2013 06:07 AM
