Old 04-27-2017, 08:36 PM   #1
scubastove
Drives: Subaru BRZ Series.Blue
Drifting on Pilot Super Sports?
Hi all, I'm considering throwing on a set of PSS. Question though..
I'm a modest driver but every now and then like to get the tail end loose. Will I still be able to oversteer/drift with PSS? Or is the grip too much for the engine to break the wheels loose? Stock wheels FWIW, I'll be getting 225/45ZR17. Thanks!
scubastove is offline   Reply With Quote
Old 04-27-2017, 09:18 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You can still provoke the car to rotate. MPSS aren't really all that sticky of a tire. They're a great DD tire, but they aren't like RE71s or RS3s or anything like that.
I was still able to get my car to rotate and break loose with a little bit of provoking when I was running 18x9.5s on 265 width tires. It might not be as progressive, and the speeds necessary to do it may not be as low compared to the stock rubber band tires, but it's still easily doable.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
strat61caster (04-28-2017)
Old 04-27-2017, 10:37 PM   #3
scubastove
Interesting. Yeah, I can't see why a quick clutch kick won't break the tail loose. Thanks!
Old 04-27-2017, 10:53 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Here's my car on 255-section MPSS still breaking them loose without too much effort... (stock power)
[ame="https://www.youtube.com/watch?v=7TxCZ6Un104"]255 Section Michelin PSS: Yes Burnouts Are Still Possible - YouTube[/ame]
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 04-28-2017, 01:33 AM   #5
Impureclient
Drives: 2015 FR-S
I went through mine in less than 8k miles and although I get sideways a little bit here and there, I don't track the car. I just bought some Firestone Firehawk Indy 500s in the same 225/45 that are getting installed on Monday.
I would look at all the reviews on them and see if you want to spend about $200 less for what appears to be a very comparable tire to the MPSS. And like everybody else said, it is easy to break the tire loose
when they were new and now that they are at the end of their life, they are sliding around at the least bit of provocation.
Impureclient is offline   Reply With Quote
Old 04-28-2017, 03:16 AM   #6
JDM4E
Drives: Honda Accord Euro
Check this out, they did exactly what you want to do, from stock to 225/45 MPSS
[ame="https://www.youtube.com/watch?v=kqhHPssCXMA"]Tracking & Drifting - Long Term Scion FR-S - Everyday Driver - YouTube[/ame]
JDM4E is offline   Reply With Quote
Old 04-28-2017, 09:15 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Yes, I'm running 255 PSS in the rear and have no trouble getting the back end out, doesn't even need a clutch-kick.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-28-2017, 09:23 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
So I think that the PSS is a really good tire, it communicates super well, it has a lot of grip without being super sticky and too much for what you're trying to do.
I run Bridgestone S-04's in 225/45-17, and I consider them to be very close to the PSS in dynamics, grippiness, etc. I always refer to them as the poor mans PSS, especially since every spring they have a $70 rebate.
I have no issues getting the rear end out with momentum, a clutch kick, or a bit of a launch and a snap of the wheel.
You'll like the PSS, but keep in mind if you're putting the tail out all the time, they won't last all that long. The S-04 is a bit cheaper so it's more palatable to run through them.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 04-28-2017, 10:26 AM   #9
radroach
Drives: car
they said they were on the all seasons
Old 04-28-2017, 02:54 PM   #10
JDM4E
there is a close up in that video @ 11.57 that clearly says Michelin Pilot Super Sport
Old 04-28-2017, 02:57 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes, but there are cheaper tires to drift on.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
churchx (04-29-2017), Mad1723 (04-29-2017), strat61caster (04-28-2017), wparsons (04-28-2017)
michelin, pilot super sports
Michelin Pilot Super Sports TimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 06-10-2017 03:35 PM
Two Michelin Pilot Super Sports 225/45/17 Tolgadince Wheels and Tires 5 01-13-2016 06:02 PM
FS Michelin pilot super sports 245/40/17 NEW APEXIT53 Wheels and Tires 2 08-28-2015 05:13 PM
215/45/17 Pilot Super Sports $60 Thevillageidiot Wheels and Tires 4 01-24-2015 01:22 AM
Pilot Super Sports Got3n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-10-2012 12:23 AM
