Old 04-26-2017, 02:53 PM   #1
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
coolant/fuel gauge working... I might have an idea or not?
I have been thinking about the fuel / coolant gauge functions and this is kind of getting to me. Any of you that have done a swap and does not have coolant/fuel working I may have an idea but I don't have the car to test it on.
Here goes
By bypassing the can network controlling the gauges (fuel/coolant) is there a way to solder in the signal wire to the +side of the gauge motor, from the fuel level sender and getting the needle to work under that instead of the combination meter. The level sender and coolant are variable resistors in a way so Im wondering if it would match to what the gauge wants.
If the voltage is too high maybe put in a resistor in series to drop the voltage going to the gauge for getting the right readings corresponding to what the sensor is saying.
Anyways this is just a thought if I had a cluster in my hands I would try it out and get back with results but any of you that have free time on your hands and would like to have a functioning fuel/coolant gauge "maybe" this could work.
cheers
rob 2fast4u is offline   Reply With Quote
Old 10-02-2019, 09:58 AM   #2
3UZ86
Drives: Currently building a 3uz 86
Hi Rob. Any luck with the above mentioned idea?
3UZ86 is offline   Reply With Quote
Old 10-02-2019, 10:22 PM   #3
geraldjust
Drives: MR2, Sliver BRZ
nope thats not possible, the needles are sepper motors. not like a older style clusters. So you cant solder directly to it. Fuel consumption are calculated by the ECU and passed on to the cluster as its consuming to give a more accurate number and also the "fuel economy" part of the cluster. Same with temperature. its purely digital. Unless you want to run the FA20 temperature sensor and keep the stock ecu. but without somehow faking the signals needed to fake the ecu RPM then not sure its possible at all with just connecting to the needles directly.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 10-03-2019, 12:27 AM   #4
3UZ86
Hi Gerald. Thanks for that response. Okay yes well temperature I plan to use a dual temp sensor so no issues there. Rpm I am still trying to troubleshoot, I know one must use a crank pickup signal(simple) but I'm pretty sure it requires the cam sensor signal as well(this I am really not sure how to mimic).
FS: AEM air/fuel gauge 264grendel Miscellaneous 16 02-24-2017 12:06 PM
OBD2 not detecting but vent gauge working Howardwei Software Tuning 1 05-26-2014 02:24 PM
Coolant Temp Gauge? Pacific Auto Issues | Warranty | Recalls / TSB 4 01-20-2014 04:00 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
