Drives: 2017 Subaru BRZ Yellow Series
2017 BRZ AC Removal
Hi, I am installing the Speed by Design 500x turbo kit and while everything is apart, I wanted to also remove the AC system so save some room for everything and make the car just a bit lighter. I don't personally ever use the AC so there is no point in keeping it! Now my question is what are ALL the parts I have to remove or replace? I know I have to remove the AC condenser in front of the Radiator and also replace the AC pulley with a Delete Kit:
http://www.ft86speedfactory.com/race...l#.WPqhjN33aEc So what else should I remove or replace or add? I'm also a first timer at modifying a car or turbo charging it so please no bug words 😂 |
Drives: '15 BRZ RA
Why don't you use the OEM AC deletion kit? You can find it here:
https://www.japanparts.com/parts/detail/46246 There was also another switch, but I think you cannot change it in the yellow series. You have different switches. |
| The Following User Says Thank You to nikitopo For This Useful Post: | Tcoat (04-25-2017) |
#3 | |
Again thank you for this 😁 |
| The Following User Says Thank You to JAK_SPYRO For This Useful Post: | nikitopo (04-24-2017) |
#4 | |
Drives: '15 BRZ RA
Ask Yuki if this part is compatible with the 2017 car (yuki AT japanparts.com). I don't think you'll have issues, but just to be sure. |
Ok so he responded that this kit is the exact same as:
1. http://www.ft86speedfactory.com/suba...html#.WP6gnfny And 2. http://www.ft86speedfactory.com/race...l#.WPqhjN33aEc So far all I know is I have to change the pulley to one of these 2, and then remove the AC condenser and block the pipes on both sides of it. If I'm missing someone please let me know |
| Tags |
| ac delete help, ac removal help |
| Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift | ModinJapan | Southern California | 1 | 01-25-2017 01:46 AM |
| 2017 Acura NSX vs. 2017 Nissan GT-R | JPxM0Dz | Other Vehicles & General Automotive Discussions | 1 | 10-19-2016 02:50 PM |
| Controlling the nannies in 2017 vs. pre 2017 | mdm | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 10-05-2016 12:11 AM |
| ABS Removal | Nigelr32 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 08-18-2015 07:46 PM |
| bug removal | TazMotorsports | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 30 | 03-31-2015 11:30 AM |
