Old 04-20-2017, 10:56 AM   #1
jcutner
jcutner's Avatar
Drives: Scion FR-S
Bringing winter tires over from another car?
I have a Kia Rio right now with Winter Tires on, and I apologize but I don't remember the exact Tire specs apart from the fact they are R15's. (and also, would 15"s be too small for winter tires on an FR-S?)
I'll update the thread once I get a chance to look at them again.
I was debating giving the tires away as my lease is up in June, and obviously I'm hopeful to get an FR-S.
But then I thought, can I just remount these tires onto appropriate steel rims for the FR-S come winter so I don't need to buy new winter tires? These tires still have a lot of tread on them (I don't drive my car much).
What would I need to know? The dimensions for the winter tires of course, and then I'd need to know the right type of Steel Rim type appropriate for the FR-S? My Rio is a 4 bolt, for the wheels.
I tried to see if there was a thread that would help cover this but I wasn't quite sure where to begin, when it comes to remounting tires onto new rims.
Is there a specific thing I should be looking for, to make sure the steel rims will fit the 5 bolt pattern for the FR-S or am I overthinking this?
As in, just bring my winter tires/rims into a tire shop, and say, I need new steel rims to mount these tires on for an FR-S?
jcutner is offline   Reply With Quote
Old 04-20-2017, 12:16 PM   #2
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Using TireRacks website, they dont offer a 15" package for our cars, so not likely you can use the 15" winter tires. 16" is the smallest, likely due to the front brake clearance.
BWilky is offline   Reply With Quote
Old 04-20-2017, 12:21 PM   #3
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Some people have fit 15s, but it'd take some research to find the right specs and you're probably pretty limited on options.
Just get some 16s and 205/55 winters. Bugeye WRX wheels are a great option for winters.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-20-2017, 12:51 PM   #4
jcutner
jcutner's Avatar
Drives: Scion FR-S
Ah that's too bad. Well, worth a shot!
Old 04-20-2017, 02:53 PM   #5
strat61caster
strat61caster's Avatar
According to this all Kia Rio's have 4-bolt wheels.
4-hole wheels don't fit on 5-bolt cars like the 86 unless you want to spend a bunch of money on spacers. Maybe possible but likely not worth it, sell 'em and get the right wheels.
https://www.discountedwheelwarehouse..._Reference.cfm
ineedyourdiddly
Old 04-20-2017, 03:07 PM   #6
Not a hope they would work even if the right number of holes!
Tires for Subaru BRZ/FRS/86
  • Diameters: 16.0'' - 19.0''
  • Width (mm): 205 - 245
  • Tire aspect ratio (%): 30 - 55
  • Smallest tire size: 205/55R16
Tires for Kia Rio
  • Diameters: 15.0''
  • Width (mm): 185
  • Tire aspect ratio (%): 65
  • Smallest tire size: 185/65R15
Old 04-20-2017, 04:25 PM   #7
jcutner
jcutner's Avatar
Drives: Scion FR-S
I know the 4 bolt rims won't fit, as I was planning on remounting the tires themselves onto new steel rims for the FR-S, but I wasn't sure if there are 15" 5-bolt steel rims that will work on the FR-S, but it does seem like 15"'s are too small for the FR-S.
The Following User Says Thank You to jcutner For This Useful Post:
strat61caster (04-20-2017)
Old 04-20-2017, 04:29 PM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Not worth it, the only way to do it cleanly would be to do a 4 pot brake swap up front and run a rally wheel
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 04-20-2017, 04:42 PM   #9
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I believe 15s are only possible at the rear of the car, and that's only with some extremely careful wheel selection.
venturaII is offline   Reply With Quote
Old 04-20-2017, 05:07 PM   #10
KnightRyderx2
Drives: 2014 FR-S
15" Watanabes fit...
KnightRyderx2 is offline   Reply With Quote
Old 04-20-2017, 06:14 PM   #11
venturaII
venturaII's Avatar
Front too?
Old 04-20-2017, 07:14 PM   #12
KnightRyderx2
Drives: 2014 FR-S
Originally Posted by venturaII View Post
Front too?
Yup. There is a couple 86s on their website with 15s on.
Also a rocket bunny in California is running 15 Watanabes from his AE86. He also did 5x100 to 4x114.3 spacer.
Old 04-20-2017, 08:43 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
We need more of confirmed fitment 15" in our wheel directory.
Old 04-20-2017, 11:04 PM   #14
jcutner
jcutner's Avatar
Drives: Scion FR-S
I'm sure they'd make for some expensive winter rims!
FS: Weathertech mats, Staggered 18 inch Rims and tires, 17 inch winter tires Tdot Canada Classifieds 19 02-20-2017 10:18 PM
FS: Goodyear UltraGrip Ice WRT 215/45/17 winter tires (tires only) Clawz Wheels and Tires 0 11-04-2016 08:46 PM
My first winter approaching, need some winter tires. Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 01-05-2016 08:56 PM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
