Old 04-19-2017, 08:21 PM   #1
timmydatooth
Drives: Scion Frs
how to remove e brake button?
So I'm trying to swap out me e brake button. But I have no clue how to get it off. All the videos I've seen say to just twist it and it should come off. I've tried vice grips and turning it it in the direction of the passengers side seat but it just keeps spinning and spinning. It doesn't even feel like it's getting loose. Not loose enough to turn with my hand. Has anyone swapped out there ebrake button? Please help this is killing me lol.
timmydatooth is offline   Reply With Quote
Old 04-19-2017, 08:58 PM   #2
15limited
15limited's Avatar
The button just keeps spinning? My OEM button was on there pretty tight, had to clamp down hard with vice grips.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 04-19-2017, 09:11 PM   #3
timmydatooth
Drives: Scion Frs
Yeah like it keeps spinning as if it's not even getting loose. When I first spun with the vice grips I heard a snap or click noise and I thought I got it. But I guess not? Which way do u turn it to get it off?
Old 04-19-2017, 09:12 PM   #4
15limited
15limited's Avatar
Oh well in that case you might have broken the rod that the button screws onto, you'll have to pull your center console unless someone else knows something I don't?
Old 04-19-2017, 09:20 PM   #5
15limited
15limited's Avatar
You've lost function of the ebrake now right? Might have snapped the cable?
Old 04-19-2017, 09:50 PM   #6
timmydatooth
Drives: Scion Frs
No ebrake still works fine. But the button is scratched up to hell
Old 04-19-2017, 09:59 PM   #7
15limited
15limited's Avatar
Yeah I f**ked mine up taking it off. I'm not sure then, it should spin off. Video? I'm not sure what the guts look like of the ebrake handle. I would assume the rod that the button threads onto goes down to a lever of some sort that pulls and releases the cable. Perhaps the rod broke free of however it is fasten to the bracket or hinge, allowing it to still function but letting the rod spin in place. Try pulling up, or out, on the button while unscrewing it.
Old 04-19-2017, 11:01 PM   #8
norcalpb
norcalpb's Avatar
Keep turning it!
Old 04-19-2017, 11:12 PM   #9
timmydatooth
Drives: Scion Frs
Originally Posted by norcalpb View Post
Keep turning it!
Haha I am! My freaking hand is sore now from turning so much! Gonna give it a rest and try to keep turning it tomorrow. I got it to the point now where I can twist it with my hands but it still doesn't seem like it's gonna come out
Old 04-20-2017, 12:37 AM   #10
norcalpb
norcalpb's Avatar
have you tried removing the leather hand brake itself? I found I was better able to get a better grip on my e brake knob with tools. For me it took like 10 double-handed rotations with a set of pliers which destroyed my stock knob but I got that sucker off.
Old 04-20-2017, 10:17 AM   #11
timmydatooth
Drives: Scion Frs
I will try that today. It just bothers me because I see so many people take off the button without having to take off the hand brake cover. Is it really possible that the rod that the button is threaded on snapped and is just spinning every time I try to twist off the button?
Old 04-20-2017, 10:34 AM   #12
KnightRyderx2
Drives: 2014 FR-S
If the rod snapped, you wouldn't have a functioning ebrake or at the most it will be intermittent. Also you will be able to just take the button out without screwing it and it will have a bit of the rod connected to it. There is a spring in there right under the button that provides the tension to keep the button up. The rod/button is very fine threaded and it takes a while for it to come off.
Like said you can take off the grip and it makes it all little easier and then you can kind of see whats going on in the ebrake. Its held on with a little bit of glue so just turn it side to side while pulling up and it will come off. I did it this way. Just make sure you are ready to stop once it comes off, if you go to crazy you will punch your head unit or something when it pops off.
KnightRyderx2 is offline   Reply With Quote
Old 04-20-2017, 10:37 AM   #13
timmydatooth
Drives: Scion Frs
if I take off the rubber grip part and ruin the glue that holds it, will it still look and feel the same when I slide it back on? or will it be all loose?
Old 04-20-2017, 10:42 AM   #14
KnightRyderx2
Drives: 2014 FR-S
You wont really "ruin" the glue that holds it. It will still look and feel the same and it will not be loose after you put it back on. If you leave the car in the sun for little while that will warm up the glue and make it easier to take off. Its not a one time use glue, it's more of a rubber/silicone type of adhesive.
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
timmydatooth (04-20-2017)
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
Can someone tell me how to remove BRZ Limited start button/tray/USB MikeM7 Cosmetic Modification (Interior/Exterior/Lighting) 3 02-22-2015 07:43 PM
e-brake removal, spacer to remove backplate puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-31-2014 06:48 PM
How much can remove from Brake MC? ZionsWrath DIY (Do-It-Yourself) Guides 0 11-11-2013 07:27 AM
How to: Remove third brake light for tint/cleaning jimmillion DIY (Do-It-Yourself) Guides 0 08-12-2013 08:47 PM
