Old 04-14-2017, 09:13 PM   #1
NickDC88
NickDC88's Avatar
HID Light Issue
So today I installed what I believe to be monogram headlights. I thought they were GT86 but the harness only had 6 wires. The new lights did not come with ballasts, bulbs or harness. So I also installed a OLM HID kit. The HIDs will turn on, but after about 15 seconds they begin to change color and then shut off. I can turn them back on immediately but after another 25 seconds they turn off. Is this the case of a bad relay? Bad wiring?
NickDC88 is offline   Reply With Quote
Old 04-26-2017, 12:13 PM   #2
NickDC88
NickDC88's Avatar
Disregard. Swapped my old ballasts with the new ones and they work fine. Not sure why. Also, my headlights are JDM because the cutoff is reversed. Not sure why they only had 6 wires though. Oh well!
Old 04-26-2017, 04:12 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
might want to adjust the cutoff for the JDM lights. You might be blinding other drivers.
Old 04-26-2017, 05:55 PM   #4
ryoma
ryoma's Avatar
the JDM headlights were NOT designed to be used with driving on the right side of the road. please take them off since you are just making it more dangerous for yourself and others around you. for example, the sloped cut-off will be on the wrong side which will blind oncoming drivers as well as not illuminate the right side of the road where the road signs and pedestrians are.
Old 04-26-2017, 06:46 PM   #5
NickDC88
NickDC88's Avatar
Already did 👍👍
Lol take them off? I have adjusted them. And the cutoff can be swapped. Plenty of people have done Gt86 lights on USDM twins. Chill. It's not the end of the world.
Old 04-26-2017, 08:18 PM   #6
ryoma
ryoma's Avatar
Already did 👍👍
did you disassemble the headlights? as far as I know, that is the only way to swap the cut offs since it is a physical piece inside the projector. obviously it is not the end of the world, but how would you like it if someone was driving towards you with their high beams on? that is what it will look like for oncoming traffic if your cutoff is on the wrong side.
if you did correctly swap the cutoffs, then kudos to you and glad that you know about it rather than running it as it is.
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
Tag Light Issue golfyankee2121 Issues | Warranty | Recalls / TSB 10 09-11-2015 12:57 AM
Daytime Running Light Issue AnthonyArcaro Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2014 07:46 PM
Fog Light Wiring Issue! ToyoGT86 Scion FR-S / Toyota 86 GT86 General Forum 2 10-24-2013 01:45 AM
Fog Light Wiring issue? ToyoGT86 Electronics | Audio | NAV | Infotainment 0 10-23-2013 11:25 PM
