Old 04-13-2017, 12:03 AM   #1
Armin93
Drives: Toyota 86 GTS
After installing UEL PSR headers
My exhaust got very loud and raspy after putting on the headers
Now i have messaged ft86speed factory asking them for a solution and they told me hks dual resonated front pipe will most likely fix the problem
Is anyone running this front pipe? How does it compare to the stock front pipe
Armin93 is offline   Reply With Quote
Old 04-13-2017, 01:48 AM   #2
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
You're taking out a catalytic converter by putting on PSR UEL Headers so your exhaust is naturally going to sound raspier.
WOuld be worth knowing what catback and front pipe you have on at the moment.
An HKS catless front pipe is probably just going to make your car louder (Regardless of whether it's dual resonated) and raspier since that will get rid of the other cat.
Wise is offline   Reply With Quote
Old 04-13-2017, 04:53 AM   #3
Armin93
Well i'm running stock front pipe with greddy sp elite axle back
I was told rasping was caused because of the not so good quality of the mid pipe and front pipe
Old 04-13-2017, 08:27 AM   #4
dattran86
Driver
Drives: 2013 Whiteout FRS
stock FP is probably the most quite FP out there, so you probably want to keep that. you probably wont see a much different in noise level when you upgrade to the HKS FP.
But a Catless header pair with just an axle back wouldn't be very raspy. and you have a very quite axle back as well.
Assuming you still have your oem FP and Midpipe, Keep the exaust system like this for a couple weeks you will get use to the noise level.
Trust me, whenever you do an exhaust mod at first you always think its too loud but give it a month and you'll probably thinking to yourself its too quite now.
Not trying to knock a sale away from Ft86SpeedFactory, those guy are awesome and have huge support for our platform. but the HKS likely won't fix your problem. you can sell the current header and grab a Catted header is a better investment than a new Front pipe
dattran86 is offline   Reply With Quote
Old 04-14-2017, 07:48 PM   #5
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
As the other member said. Not only are you removing a Cat, the header you bought is also probably thinner. Thinner walls will create rasp. Another thing is there is now heat shield which helps reduce volume and rasp.
The best solution to reduce volume and rasp is to do one of a few things.
Go back to stock header
Switch out your Catback Exhaust for something quieter like the Q300, R400, Perrin Ressonated 2.5" CBE or the 2.5" Nameless Axelback with 5" Muffler.
Sell your current header and buy a catted header.
There is nothing quieter than our stock front pipe. I have switched mine out for the JDL ultra quiet which has a high flow cat and resonator and its still louder than stock.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 04-17-2017, 11:26 PM   #6
Wise
Circle Work Clerk
Yeah agreed. Swap your catback for a Q300 and keep your stock FP and the PSR headers.
I've got Tomei UEL headers which are pretty much the same as the PSR's plus a Q300/stock FP combo and the noise is noticebly better than stock, but not too loud or raspy. The only time I ever hear rasp is through first gear if I launch it on a cold day.
Old 04-17-2017, 11:50 PM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If it helps any, I have the Nameless EL headers, catted and resonated front pipe, and the HKS legamax sport catback and it's very quiet of a set up. I had the Q300 on before but after 2 years, it was wearing down and becoming very loud. The HKS made it super quiet at idol and low rpms. Little to no rasp, too.
MS, CSCS, TSAC-F, CPT
Old 04-18-2017, 02:44 PM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
is this your first modified sports car?
It's loud but it's not super duper loud in my opinion.
since you already had your stock front pipe, try switching to stock catback. or like others mentioned get Q300 or quieter exhaust but little louder than stock.
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 09:42 PM
Rattle after installing headers alonsoglz7 Engine, Exhaust, Transmission 1 01-27-2015 12:02 AM
Installing Headers w/ a jack & stands Phantobe Engine, Exhaust, Transmission 20 01-13-2015 02:19 PM
Will installing new Headers void warranty? FerraraZ Issues | Warranty | Recalls / TSB 12 06-02-2014 08:44 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
