FRS 10 series #0239
Drives: #0239 FRS 10 series silver ignition
New wheels, want to know if they'll rub and best tires to run
whats going on everyone,
haven't been on here in a while since I got my new job but I'm coming to y'all with a question. I'm looking into getting some wheels for Judy (my car ) and I also need to get tires with them as well (obviously). I'm looking at 18X8.5 AVID1 AV30 wheels and Michelin Primacy tires (hey, they haven't let me down yet hahaha). my main question is am I going to be rubbing on turns and what tire size should I run so I don't rub. I know there is a tire gauge in this thread somewhere but I can't seem to find it. if someone could send the link or post it in the coments that would be great. but I also would like your feed back if anyone is running these and how they like them. are they heavy, is there clearance issues andything of the matter. I am also lowered on Eibach Sportlines so I know that will also play a roll in the rubbing factor. any help is welcomed. thanks in advance
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239 |
Drives: Stock
What's the off set? I run 18x8.5 et 35 and my tires are 245/40-18 on eibach sportline too. But I do rub if I hit a hard bump and if I make a hard turn at full speed. Normal driving no rub so I think a 235/40-18 might help but most people say go with 225/40-18. Oh and the fronts not rubbing at all it's just the rear. Been thinking of changing just the rear spring to like a 1 inch drop spring to give it a bit of rake. I really like how my tires look. Also it might not rub if let's say I get a better rear sway bar. That way there's less roll in the back! Hope this helps
| The Following User Says Thank You to -Willis-86touge For This Useful Post: | LowAndSlowBecauseNoTurbo (05-19-2017) |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | LowAndSlowBecauseNoTurbo (04-12-2017) |
Drives: Asphalt 2015 FRS
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
| The Following User Says Thank You to Brayden_23 For This Useful Post: | LowAndSlowBecauseNoTurbo (04-12-2017) |
#5 | |
FRS 10 series #0239
10 series #0239 |
Drives: '16 BRZ Limited
I'm on 18x8.5 +35 wheels with 235/40/18 Hankook Ventus V12 evo2, no rubbing here.
I am, however, on stock height for the time being though. |
| The Following User Says Thank You to meWant For This Useful Post: | LowAndSlowBecauseNoTurbo (04-12-2017) |
Dual offsets? how? et30 in the rear is a little too much. +35 to +40 is good
#8 | |
FRS 10 series #0239
Dual offsets because I'm getting 9.5 in the back and 8.5 in the front Sent from my iPhone using Tapatalk
10 series #0239 |
#10 |
FRS 10 series #0239
Oh damn, I didn't know what the ET stood for. So I put both😂😂 it's gonna be 35 front and 30 rear
10 series #0239 |
#11 |
+30 rear is too much. Some would say +35 also. I'm on +34 255/35 lowered about 1.5inches and it pokes about half an inch and rubs the rear bumper tab and is dangerously close to popping the rear fender. I also have a mild fender roll. On big bumps it hits the fender and tire has cuts from it.
#12 |
Drives: Stock
Yes only rear rubs on fast corners and on bumps if I don't slow down enough
| The Following User Says Thank You to -Willis-86touge For This Useful Post: | surfwaxsmitty (04-29-2017) |
#13 |
Drives: Stock
Got an alignment finally and no more rubbing at high speeds on corners unless I'm above 110 so thinks me needs better roll bars and il be good oh but stil rubs on hard bumps
| The Following User Says Thank You to -Willis-86touge For This Useful Post: | LowAndSlowBecauseNoTurbo (04-16-2017) |
| *Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) | wheelsco | Canada Classifieds | 4 | 10-08-2015 03:55 PM |
| Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires | themajesticone | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-04-2014 02:49 PM |
| Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! | stratodyne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2013 02:21 PM |
