Old 04-08-2017, 11:51 AM   #1
JPRodney
JPRodney's Avatar
Drives: 2016 Asphalt FRS
BC Br Type Coilovers.
This is my first car with coil overs. I installed these myself and the first time doing something this large. I found that my ride is really rough and any large bump or manhole I drive over makes the car feel like it's going to explode.
I've played with the dampening, on the softest settings it's okay but still pretty rough. I believe that my spring load is incorrect as I didn't use the 2-3mm from factory.
The ride is overall really rough and bouncy. I believe I can fix the bounce with just adjusting the dampening but then I feel like the car will explode.
Any ideas? Complete noob.
Asphalt FRS - Ontario, Canada
JPRodney is offline   Reply With Quote
Old 04-08-2017, 12:25 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Sounds like the preload is not set correctly. what are your spring rates?
The Following User Says Thank You to NyC Zn6 For This Useful Post:
JPRodney (04-08-2017)
Old 04-08-2017, 02:20 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
Bouncy may be not enough damping for the spring rates.
Crappy ride is something I hear a lot about with BC... but in this case I'm guessing it is spring rate and lack of adequate travel most likely to be the culprit.
Note, I put two season on 10/12k springs, so am no stranger to higher rates. And while potholes and similar were always pretty rough if deeper than an inch, most other times the ride was remarkably smooth, all things considered.
The Following User Says Thank You to cjd For This Useful Post:
Old 04-08-2017, 06:43 PM   #4
JPRodney
JPRodney's Avatar
You sir were correct!
I managed to fix it. So the problem was I didn't set the preload correctly and basically the car had 0 travel. So I fixed it, just a stupid mistake from me. First car still learning! Glad I didn't break anything.
The Following User Says Thank You to JPRodney For This Useful Post:
cjd (04-08-2017)
FS: BC Racing BR type coilovers deSpised Brakes, Suspension, Chassis 4 05-08-2015 12:38 PM
BC Racing BR type coilovers EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 03-25-2015 02:25 PM
BC BR-Type Coilovers question.. VADER Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-04-2013 04:36 PM
FS: BC Racing Type BR coilovers twincamRob Brakes, Suspension, Chassis 3 08-28-2013 10:51 PM
FS: BC Coilovers BR type $800 OBO NemeGuero Brakes, Suspension, Chassis 18 02-26-2013 04:35 PM
