Old 04-06-2017, 06:37 PM   #1
LeosFRS
Drives: 2013 FrS, Whiteout, MT
Clutch replaced, Dragging sound over 50mph
Im new to this forum but Ive owned a Frs for over 2 years now. I replaced the clutch over the weekend, currently at 55k. Throw out bearing was complete shit. The problem im having right now is some type of dragging sound only when i go above 50mph (sounds like im dragging something under the car). Nothing else seems wrong. No grinding sound in idle/ or when shifting. Shifts perfectly fine & accelerates fine as well. Seems like the clutch is engaging/disengaging correctly. Currently in the break in process for the clutch. Any ideas on what the sound might be? Will post a video of sound soon.
LeosFRS is offline   Reply With Quote
Old 04-06-2017, 08:08 PM   #2
humfrz
Hello LeosFRS and welcome to our forum ......
Maybe, just maybe, when you get up to speed, a piece of one of the underside or wheel well plastic shields is fluttering and dragging on the ground or rubbing against a tire.
Welp, that's my guess ......
humfrz
Old 04-06-2017, 08:53 PM   #3
LeosFRS
I removed the fiberglass underside and kept the aluminum guard but nothing else is loose. That's the same thing i thought of. Even pulled over to see if I was dragging something when I heard the sound but nothing..
Old 04-06-2017, 09:57 PM   #4
LeosFRS
Here is the video of the sound
Old 06-12-2017, 06:20 PM   #5
D_bullcock
Drives: 2013 silver brz
Didnyou ever find out what was wrong? I'm currently having the same issues
D_bullcock is offline   Reply With Quote
Old 06-14-2017, 02:48 PM   #6
celek
Resident Gear Head
celek's Avatar
Sounds like heat shield being pushed down onto driveshaft
celek is offline   Reply With Quote
ACT clutch dragging/not disengaging FirestormFlex Engine, Exhaust, Transmission 5 09-14-2020 02:18 AM
Clutch Replaced StOpNG0x Engine, Exhaust, Transmission 46 08-31-2016 01:35 AM
Clutch dragging radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 08-19-2015 02:32 AM
clutch sound? frsqc Issues | Warranty | Recalls / TSB 4 08-03-2015 03:48 PM
Replaced front speakers with component set - sound is worse AlexTheGreek Electronics | Audio | NAV | Infotainment 37 04-15-2013 09:58 PM
