Old 04-04-2017, 09:54 AM   #1
reynierpm
Drives: Toyota 86 2017 Black
Car shutdown as soon as I press the brake after install a Clifford 5806X
I've just got installed a new brand Clifford 5806X alarm & remote start system on my Toyota 86 (2017). Everything seems to be "working fine" but now after I start the car with the remote and press the brake it shutdown instantly and I can't move the car, I am missing something here? Is that a security stuff coming from the system? An error on installation? How I can fix this?
reynierpm is offline   Reply With Quote
Old 04-04-2017, 09:56 AM   #2
Many aftermarket remote starters require you to restart the car with the key/pushbutton after starting the car with the remote. It is a safety feature so that nobody can just jump in your remotely started car and drive away. I bet that is all it is.
Old 04-04-2017, 09:58 AM   #3
reynierpm
And how do I restart the car using the key? I mean what are the steps?
  • Power on the car using the remote
  • Put the key on the hole and ..... from here I am lost
Old 04-04-2017, 10:17 AM   #4
They can all be different. Check the manual for the system. In the case of my wife's new car she has to simply push the start button without stepping on the brake.
Odds are you just have to turn the key to the run position. DO NOT go too far and hit the start position with it running. If you do that noise will haunt your dreams forever.
burningjello (04-04-2017), humfrz (04-04-2017)
Old 04-04-2017, 10:22 AM   #5
reynierpm
I feel like I will burn my car computer or internal system forever, could you take a look here https://www.manualslib.com/manual/75...6x.html#manual and let me know what I should look exactly?
Old 04-04-2017, 10:32 AM   #6
My guess was right
Remote Start Features
Key Takeover
When you are ready to drive
The system keeps the engine running until the vehicle is ready to be
driven. To perform Key Takeover:
Disarm the system and enter the vehicle, do not step on the foot brake.
insert the key, turn it to the run position, and then step on the foot
brake, the remote start then turns off.
The parking lights turn off to indicate remote start is off, and then
after a few seconds the remote plays the Remote Start Off mes-
sage.
The vehicle is ready to drive
funwheeldrive (04-04-2017)
Old 04-04-2017, 10:47 AM   #7
reynierpm
Ok, so if I am following you I depend on both the remote start and the car key to make the car ready to drive? Is this a one time thing or I must do this all the time?
The car has four possible positions on the key: LOCK, ACC, ON and START, is ON the right position in this case?
Old 04-04-2017, 10:50 AM   #8
You need to do it every time. Just put the key in and turn it to on and then step on the brake to turn off the remote start. The car will just keep running as if you had started it with the key in the first place.
The whole thing works that way so that the key must be present in the car and nobody can steal it while it sits running and unattended.
reynierpm (04-04-2017)
Old 04-04-2017, 11:58 AM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
1) remote start the car
2) put key in the cylinder and turn to ignition on position
3) put foot on brake (remote start disabled) and car will still be on
Old 04-04-2017, 12:14 PM   #10
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
My guess was right
Wow. You got Tcoat to RTFM for you. Thats a new one.
PandaSPUR is offline   Reply With Quote
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
Crashdummy (04-04-2017), treminaor (04-14-2017)
Old 04-04-2017, 12:29 PM   #11
PandaSPUR (04-04-2017)
Old 04-04-2017, 01:55 PM   #12
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I think that is a first. OP has the manual in front of him but still needs to told how on the www to understand. If the web is ever down for real the world will end.
PetrolioBenzina is offline   Reply With Quote
Old 04-04-2017, 03:55 PM   #13
humfrz
@Tcoat is getting soft ........
humfrz
Old 04-04-2017, 04:06 PM   #14
humfrz
I just went through this whole conversation with the wife last week so I took pity. Besides there have been worse questions asked and OP was at least appreciative!
humfrz (04-04-2017)
Custom N7 headunit install (Startup / Shutdown video) Looking for help. AtlasMick Electronics | Audio | NAV | Infotainment 1 12-29-2014 11:51 AM
frs/nexus 7 install - looking for startup / shutdown video AtlasMick Electronics | Audio | NAV | Infotainment 0 12-21-2014 03:21 PM
Compustar/Clifford fukamoto Northwest 7 01-11-2014 04:24 PM
OUTCAST || Rocket Bunny FRS Photoshoot in the Rain by Clifford Sutrisno @ TimeATK Outcast Garage BRZ Photos, Videos, Wallpapers, Gallery Forum 3 05-08-2013 06:31 PM
Official FT-86 II Concept Press Release, Press Photos, Videos Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 126 05-18-2011 02:27 AM
