Drives: Subaru BRZ
O.F.T or ecutek?
Hey guys
I know people asked this question like a million time but I'm new here so please be nice ![]() I got a Subaru BRZ with tomii header (eul) And greedy intake I relly want to know what the difference between ecutek and O.f.t?. And witch tuners you guys recommend for ecutek and why? A friend told me that delicious tuner is the best but I wanna know why? Please help me to figure it out but don't tell me only names of tuners Tell me the name and what this tuning doing to the car Thank you very much guys. |
maybe start here
http://www.ft86club.com/forums/showthread.php?t=106068 lot of info on oft in coloured links below andtuning info see also links below |
If your buddy says delicious tuning is the best, maybe he can explain why he thinks that.
#4 | |
Drives: 86
ecutek is flasher with same more options .as racerom both work with boost . e85 . lc/ffs both use stock ecu both lock the ecu in my view . both same |
Drives: 86
ecutek =headache
#6 | |
Drives: '15 BRZ RA
OFT is based on an open source community and the changes are not locked. It comes bundled with some predefined ROMs made by a single tuner, but you can also use the hardware to upload other open source tunes. In both cases, you should know that noone has an access to the actual source code. Everything is found by a process called reverse engineering. They know most of the ROM's functionality and what the different tables are doing, but the knowledge will never be a 100%. Last edited by nikitopo; 04-02-2017 at 02:24 AM. |
OFT is also on sellable if you flash back your stock tune, and you will get good money fore it second hand
Ecutek locks ecu oft does not lock ecu, but the oft does get martied to your car vin, it can be unmarried by flashing back stock tune then you can sell oft if you wanted to. ecutek you can only onsell cable kit the licience and tunes not on sellable. oft also functions as a guage display and alarms and alerts see OFT TIPS link below. As above Ecutek has more high features. you realy need to research what you want and make your own decision i have OFT, a Tactrix and Ecutek flash systems, they all work reliably and have their good and bad points. |
Drives: '15 BRZ RA
As a side note, I asked an engine tuner in Japan if they are doing ECU tuning. Although, they said it'll give better results they mentioned that it is not so common and most of their customers don't do it.
Drives: 2013 Scion FRS
OFT is all done by yourself. You get free premade tunes, customize them, there's 2 step, flat foot shift, and so on.
EcuTek is online or in shop. Some dude makes a tune for you, it's custom, and you have to pay for new tunes. I went OFT, i want full control over my car. Some go EcuTek, they want proffessional, custom tunes. You decide, they both have ups and downs. Sent from my HTC6535LVW using Tapatalk |
#10 |
Drives: 13 frs red
My experience with oft has been very positive. E85 tune gave me 20+ horses for 500 bucks. Can't complain.
#11 |
Drives: United States
imo OFT for NA and ecutek for FI
#12 |
Drives: 13 frs red
#13 |
Ecutek is definitely worth the money if you can pay for a ton of dyno time.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#14 |
| WTB ECUTek used | xoBethxo | Want-To-Buy Requests | 0 | 04-22-2016 01:05 PM |
| ECUTEK | FR-Shred | Want-To-Buy Requests | 1 | 06-13-2015 02:21 AM |
| Ecutek + SCG-1 | ofuts | Forced Induction | 2 | 06-12-2015 04:24 PM |
| I need help on which ecutek I should get, stg 1 or 2 | Frsexxxy | Engine, Exhaust, Transmission | 22 | 03-29-2013 10:45 PM |
| Which should I get ecutek stg 1 or stg 2? | Frsexxxy | Engine, Exhaust, Transmission | 5 | 03-21-2013 01:10 PM |
