Old 03-24-2017, 01:43 AM   #1
SeanJohn
The Don
SeanJohn's Avatar
Drives: 2015 Metallic Grey BRZ Limited
Damaged Exhaust Manifold Stud
So last fall I installed the TOMEI UEL headers and all has been great with them. Tonight, however I was changing my oil and investigating what looks like a minor oil leak. I also noticed one of my header nuts was loose (attaching to the block) and so I decided to tighten it down. Well it spun and spun and finally I realized the stud thread is damaged and stripped! I think it happened as I pulled the stock headers off originally and they scraped against the threads.
Curious if anyone knows how difficult it is to remove a stud from a block or if they recommend going to a shop.
SeanJohn is offline   Reply With Quote
Old 03-24-2017, 03:25 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Maybe try a die on it first? Though not surr how messed up it is so maybe not an option
Old 03-29-2017, 11:03 PM   #3
Shadow8948
Drives: 2013 Scion Fr-S in whiteout
Bumping this because I'm in the same boat. Header install boogered the threads and now they don't thread on correctly. Will try tap and die but if that fails, Is there a specific process for this? Or is it pretty straight forward
Shadow8948 is offline   Reply With Quote
The Following User Says Thank You to Shadow8948 For This Useful Post:
Legionsk88 (03-30-2017)
Old 03-29-2017, 11:08 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
https://www.google.com/webhp?sourcei...nifold+studs&*
Old 04-15-2017, 06:35 PM   #5
Shadow8948
Op did you resolve the issue?
Old 04-15-2017, 08:35 PM   #6
Shadow8948
Just wanted to update this real quick. I ordered a set of oem studs and nuts from eBay for $21.
http://m.ebay.com/itm/Genuine-Subaru....c100408.m2460
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Broken Exhaust Stud During FP Install EvoPrecision8 Engine, Exhaust, Transmission 28 03-31-2015 04:21 PM
WTB: Tomei EL exhaust manifold JesseTheFlash Want-To-Buy Requests 0 08-29-2014 01:48 AM
Titanium Exhaust Manifold illmatic Engine, Exhaust, Transmission 9 06-25-2014 01:33 AM
Need factory exhaust manifold dorifuto Engine, Exhaust, Transmission 1 01-24-2013 02:05 PM
