Old 03-23-2017, 12:00 PM   #1
kravi
Drives: Subaru BRZ
Strange harmonics?
So I just got a pair of 17 x 8 RPF1s (gunmetal). Put on with spacers (of course). have 235 x 45 (the 40 height ones cost $50 more each) DD SSIIs. Driving in to work this morning, I got some loud harmonic sounds. Occasionally intermittent, but very consistent and I was hearing them around 90% of the time at highway speeds, maybe more.
Any ideas? Is this normal for the wheels? It is loud and annoying.
--Me
kravi is offline   Reply With Quote
Old 03-23-2017, 12:22 PM   #2
DAEMANO
Time Traveller
Any odd feelings in the steering wheel (vibration, tugging, etc.) My first thought was the tires were out of balance, or perhaps since the wheels may not be hubcentric and perhaps were installed improperly. Hub rings can help this. Both may not be your issue, but are the kinds of small details that often happen when installing new wheels.
Old 03-23-2017, 12:25 PM   #3
kravi
Drives: Subaru BRZ
So hub rings were installed - RPF1s need them. There is some vibration in the steering wheel, especially at speed.
Old 03-23-2017, 01:28 PM   #4
Joon525
Joon525's Avatar
Drives: 2016 BRZ
  1. Try it without the spacers and see if the noise is still there, it's free to try. (you never mentioned offset so I don't know if they're ABSOLUTELY needed in your setup)
  2. What tires? Some tires are very noisy.
  3. As previously stated, you could try getting the tires rebalanced.
  4. You used lugnuts with conical seating right?
Joon525 is offline   Reply With Quote
Old 03-23-2017, 02:41 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
200tw tend to be on the loud side. But I would remove the spaces and see what happens. Then if still there take back to the tire shop to che k the balance since there is some vibration.
Old 03-23-2017, 04:17 PM   #6
wparsons
wparsons's Avatar
It's been said, but try again with no spacers. If it's still there, have the balance checked. ZII's are a louder tire, so if there's no vibration it's probably just tire noise you're hearing. My original ZII's were significantly louder than the stock tires and my snow tires. To be fair, my RS3's and AD08R's are also really loud.
flickr
Old 03-23-2017, 07:38 PM   #7
kravi
Drives: Subaru BRZ
My bad. I put my first post up when I wasn't paying attention (I was in a meeting with partners at the office, but want y'alls feedback. No spacers. Just hub rings - the RPF1s need them to be centered.
Tires are dunlop durezza star spec II 235 x 45 (I know, but the 235 x 40 were $50 more each).
--Me
Old 03-23-2017, 07:48 PM   #8
wparsons
wparsons's Avatar
Hub rings aren't as necessary as most shops will tell you, I'm going on 4 summers with mine and no hub rings.
I'd go get the balance checked if there's a vibration in the steering wheel.
flickr
Old 03-23-2017, 11:20 PM   #9
kravi
Drives: Subaru BRZ
So I was checking tonight, and no steering wheel vibration at all. The harmonics are still there.
As for the hub ring, when we put the first wheel up, it was clear it wasn't centered properly. So that is why we used hub rings. Anyway, I don't think that would cause the weird harmonics
Since you have RPF1 I guess you have confirmed that the aero of the RPF1s isn't what is causing the sound. I thought, because it is only at speed, that the wind through the spokes of the RPF1s might be making the weird harmonic noise. But I guess not. Grrrr.
The shop, good guys all, are going to poke around tomorrow or Monday and help me figure it out.
--Me
Old 03-24-2017, 01:28 PM   #10
wparsons
wparsons's Avatar
--Me
Adding hub rings will definitely not make it worse, so you can rule those out. Without hub rings, but properly torqued down, the wheels will still be perfectly centered on the hub because of the conical seat lugs.
Without the vibration, my money is just on it being tire noise. Extreme summer tires are REALLY loud compared to most tires out there. I have to turn my hands free volume up quite a bit when I swap to summer tires, and back down when swapping to winters, because of the difference in road noise.
flickr
Old 03-24-2017, 01:31 PM   #11
Rougenite
Drives: Raven FR-S
Have RPF1s, no rings. Didnt have center caps for a long time either! No harmonics. I'm going to say its probably just tire noise like the others. RS3s were stupid loud, the MPSS are not too bad, but on some types of concrete they can be bad.
Rougenite is offline   Reply With Quote
Old 03-24-2017, 02:05 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
I haven't yet tried MPSS-es, but shouldn't they be a bit quieter then stock primacies?
Old 03-24-2017, 02:14 PM   #13
Rougenite
Drives: Raven FR-S
I dont think so, the Primacies were pretty quiet...but I also am running 245s now.
Strange request eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 26 04-09-2015 05:43 AM
Strange sounding pop Stewie BRZ First-Gen (2012+) — General Topics 8 02-16-2015 12:39 PM
(Not so) Strange Experience GAPF1 BRZ First-Gen (2012+) — General Topics 11 01-27-2014 04:00 PM
NOW THIS IS JUST STRANGE White64Goat BRZ First-Gen (2012+) — General Topics 37 03-11-2013 09:26 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
