Old 03-22-2017, 09:40 PM   #1
phrosty
Broken OBD2 connector
Hey guys,
Something has happened to my OBD2 connector where certain things will simply not get a good connection anymore, but others will. Today I failed an emissions test not because of my mods but because they couldn't connect to the darned ECU to check the readiness codes, and refused to connect through my extension cable which somehow manages to allow for a working connection.
Anyone have experience replacing the connector? It it simply a quick harness to unplug?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-22-2017, 09:57 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Originally Posted by phrosty View Post
Hey guys,
First, I would get down on the floor of the driver's seat area and have a look at the connector - it is likely a pin or two has bent out of position. Even just a little bending can result in failed connections with some cables (not all cables have the same connection tolerances). If pins are too bent, or are dislodged, your best bet will be to re-pin the plug. It's a pain, but will be worth it. While you are repinning the plug, you can add in a bracket to reinforce the plug so that the likelihood of bending pins is reduced.
Of course, if the port has stopped working entirely, check the OBD fuse in the interior fuse box to the left of the steering column.
theadmiral976 is offline   Reply With Quote
Old 03-22-2017, 10:00 PM   #3
theadmiral976
Hey guys,
Also, this thread might help: http://www.ft86club.com/forums/showt...t=39137&page=3
Within that thread, someone mentioned this replacement kit: http://www.bmotorsports.com/shop/pro...k9j6vmohvi2c43
Best OBD2 app for Iphone jslack Software Tuning 15 04-28-2019 03:38 PM
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
WTB: Main engine harness and obd2 connector Dream20b Want-To-Buy Requests 1 07-31-2015 06:41 PM
OBDII (OBD2) Connector nzer Electronics | Audio | NAV | Infotainment 35 04-21-2013 12:36 AM
