Old 03-21-2017, 09:26 PM   #1
itzaustin
Drives: 2013 FRS 10 series
Boost on stock map sensor
Topic says it all, what boost can be run on stock map sensor before I should be upgrading?
itzaustin is offline   Reply With Quote
Old 03-21-2017, 10:37 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
MAP sensors are cheap. The stock cant handle anything past 5 psi i think. So just purchase a better one.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-21-2017, 10:49 PM   #3
itzaustin
Alright thanks man
Old 03-22-2017, 06:53 AM   #4
Bobster
Drives: GT86 GTS
isn't is about 12psi??
Bobster is offline   Reply With Quote
Old 03-22-2017, 09:50 AM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Stock map sensor only reads up to 6.72 psi. I am boosted (supercharger) but my tune is scaled off the MAF so I still have the stock MAP sensor.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 03-22-2017, 07:32 PM   #6
itzaustin
Yea im just going to buy the delicious tuning 11psi map sensor its only $65 since i wont be running more than 10psi
Old 03-23-2017, 10:42 AM   #7
GsxrMe
GsxrMe's Avatar
Good call.
2014 Subaru BRZ
Old 03-23-2017, 01:33 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
What's it for? You should run a properly spec'd MAP sensor on a turbo, it's not at all required for SC applications and is known to cause issues on some of them.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-23-2017, 02:28 PM   #9
itzaustin
I'm running a custom sourced turbo my uncle put together for me, he's a mechanic in the military and fabed everything up for me as far as piping and I'll just be running a t3 turbo until I get forged internals later on to run a bigger turbo with more boost. Won't be for another year or so
Old 03-24-2017, 02:35 AM   #10
Bobster
Drives: GT86 GTS
I prefer map sensors because read the pressure on the intake manifold
Old 03-24-2017, 09:58 AM   #11
Amputechture
Drives: 2014 BRZ
I've got one I'll sell you for 50.
Amputechture is offline   Reply With Quote
Old 03-24-2017, 07:50 PM   #12
itzaustin
Pmd
Weird CEL. Boost related? P0327 Knock sensor. xkalelx Forced Induction 0 02-08-2016 09:26 AM
FS/FT: P3 vent gauge with analog boost sensor Red FRS Engine, Exhaust, Bolt-Ons 3 06-08-2014 07:10 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
