Old 03-21-2017, 06:06 PM   #1
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
90975-A2003 badges won't fit?
Ok, I am posting this hoping someone can point out something obvious I'm missing.
I ordered a Toyota replacement badge set for my FR-S from an Ebay dealer. The rear fit fine but the front was off by about a millimeter ... even though the part number was correct.
I then ordered a front one from Amazon (again, a 90975-A2003) and it has the same issues. See below, both lying out with the original Scion badge. The bottom pic was me test fitting it with one peg inserted revealing a bolt hole exposed.
What am I missing here?
Thanks!!
Captain_Awesome_Pants is offline   Reply With Quote
Old 03-22-2017, 01:25 PM   #2
mclovin85
mclovin85's Avatar
Drives: scion fr-s
Thanks!!
thats weird... i bought mine from ft86speedfactory and they fit fine, try putting the bigger one in the front and the smaller badge for the trunk
mclovin85 is offline   Reply With Quote
The Following User Says Thank You to mclovin85 For This Useful Post:
Captain_Awesome_Pants (03-22-2017)
Old 03-22-2017, 03:20 PM   #3
Strange thing is, the rear fit fine and these would be WAY too big for that one. Two front ones bought from two separate vendors with identical part numbers don't.
Old 03-23-2017, 12:36 PM   #4
mclovin85
mclovin85's Avatar
Drives: scion fr-s
wait so you got 2 rear badges but they are different part numbers?
Captain_Awesome_Pants (03-23-2017)
Old 03-23-2017, 02:05 PM   #5
Let me make sure I'm stating this properly:
I received 2 badges in my initial order. One for front, one for back. Both in clearly marked Toyota bags. One was part number 90975A2003 for the front and the other was part number 90975-02069 for the rear. The rear was about 10 mm and fit fine. The front (measuring at 12 mm) was too big for the space/holes (supposed to be 11mm).
Thinking it was a mistake, I went ahead and bought the exact part number (90975A2003) again from another vendor. That arrived, and was exactly the same as the other (12mm). Unless the thread here is wrong, that should fit. Check the pic.. the tape measure and original bags don't lie. I just don't get it.
Thanks for responding, and again... Im open to any thoughts on it.
Old 03-23-2017, 05:58 PM   #6
mclovin85
mclovin85's Avatar
Drives: scion fr-s
you should return those and get your badges from ft86 lol
Old 03-23-2017, 06:59 PM   #7
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I second that or buy a complete set from 86speed.com.
http://www.86speed.com/new-products/...toyota-badges/
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 03-24-2017, 12:35 PM   #8
mclovin85
mclovin85's Avatar
Drives: scion fr-s
that would work too... heres a pic or mine
WTB: Subaru Brz badges Professor Chaos Want-To-Buy Requests 0 05-28-2014 04:25 PM
Re-applying Badges Sivtec Cosmetic Modification (Interior/Exterior/Lighting) 3 07-03-2013 01:06 PM
Swap Toyota Badges for Scion Badges CSI:86 Exterior Parts (Aero, Lighting, Etc.) 17 05-14-2013 08:11 AM
Is anyone else going to take the badges off their FRS? MrFRsLa Cosmetic Modification (Interior/Exterior/Lighting) 148 01-03-2013 01:23 AM
No more FRS....jdm badges on the way. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 11 09-12-2012 11:06 PM
