Old 03-18-2017, 11:44 PM   #1
gantonski
Drives: 2015 BRZ
VSC/Traction Mod - What is the center 'button'?
Does anyone know what is in the middle slot for the traction control/vsc sport module? Is it possible to cut that part and insert a separate button, or are there other important widgets in there?
Thanks!
gantonski is offline   Reply With Quote
Old 03-18-2017, 11:48 PM   #2
Thanks!
It is for the snow button for the ATs.
Doesn't look like you could put anything there though.
Old 03-19-2017, 10:10 AM   #3
extrashaky
Drives: 2014 BRZ Limited
Once it's out of the car, the top part of that switch unit pops off very easily (it's held on with plastic tabs). There is a circuit board inside that runs all the way across the switch unit. The existing buttons are not separate switches. They push contacts on the circuit board to activate those functions. I suppose it's possible to mount some kind of switch in that center position, but you would have to work around the circuit board.
Old 03-19-2017, 10:40 PM   #4
Poodles
Drives: 2015 Series.Blue
Someone on the forums did it, from what I remember the board has switch pads and everything on it, the center switch part just has plastic tabs to stop it from rocking. You'd still need to wire it to something though, which is more work.
Wish I could find that thread, my search-fu is weak
Old 03-20-2017, 08:12 AM   #5
markitect
Drives: Scion FRS
Addin wiring isn't too hard, there are just open spots on the connector. I just got a used AT switch set, and some pins and probably relays depending on what you want to do.
http://www.ft86club.com/forums/showthread.php?t=112278
markitect is offline   Reply With Quote
Old 03-20-2017, 08:29 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It's the secret NAWZ button.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-20-2017, 10:16 AM   #7
gantonski
Drives: 2015 BRZ
great. thanks everyone. I have my parking garage door opener and wanted to insert that into there because i dont want another fob on my key chain and dont REALLY want it floating around in my cup holder.
I'll try to find a link or picture where someone has removed it and see if there is any room for another small circuit.
Old 03-20-2017, 02:49 PM   #8
g e
Just get the rear view mirror with home link. One can program 3 separate garage door openers.
g e is offline   Reply With Quote
Old 03-20-2017, 03:35 PM   #9
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I got a keychain-size opener on Amazon and stuck it in the slot behind the gear shift with a piece of L-shaped foam so it won't slide around:
BRZyJ is offline   Reply With Quote
Old 03-20-2017, 09:25 PM   #10
gantonski
Drives: 2015 BRZ
so the manual doesn't seem to have that information in it, but google does. i'll give that a shot tomorrow morning. thanks a lot
Old 03-21-2017, 09:14 AM   #11
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I remembered this thread.
http://www.ft86club.com/forums/showthread.php?t=92390
murdoc is offline   Reply With Quote
Old 03-22-2017, 02:32 PM   #12
g e
The home link mirror was one of the things on the Limited edition I was ambivalent about, but have grown to appreciate a lot. It's a dealer installed option for most of the Subaru models.
Old 03-24-2017, 10:52 PM   #13
gantonski
Drives: 2015 BRZ
yeah it worked out perfectly. and thanks murdoc - unfortunately his video is not available, but a pretty good post either way.
Old 03-24-2017, 11:29 PM   #14
Originally Posted by murdoc View Post
Center console snow / sport button BriRZed Electronics | Audio | NAV | Infotainment 10 10-23-2017 06:55 AM
Rewire an AT traction button into MT? Use traction toggle as an accessory? The_Understated Cosmetic Modification (Interior/Exterior/Lighting) 27 05-06-2017 11:35 PM
Part number for center pocket panel with push start button yellowfrs Scion FR-S / Toyota 86 GT86 General Forum 9 06-29-2016 10:18 PM
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Piano Black Dash Panel and Black Traction Control Button? stoneman155 Cosmetic Modification (Interior/Exterior/Lighting) 13 10-02-2015 11:09 PM
