Old 03-11-2017, 02:33 PM   #1
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
Question Blinking carat "arrow" in Dashboard Gear Display
What is that fast blinking carat looks like an up arrow that appears on the gear indicator screen in the tach?
It happens quickly any body else see it?
2017-BRZ is offline   Reply With Quote
Old 03-11-2017, 02:40 PM   #2
spike021
spike021's Avatar
Isn't that blinker that you can shift up?
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
2017-BRZ (03-11-2017)
Old 03-11-2017, 05:05 PM   #3
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
It lets you know when you should shift for best fuel economy.
It also turns off if you turn off the in-gear display.
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
Old 03-11-2017, 07:25 PM   #4
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Yea it's turned on when the gear indicator is turned on. So if you turn it off, the carrot letting you know when to shift, and the gear indicator will also turn off. I personally like it.
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following User Says Thank You to Bowen For This Useful Post:
Old 03-11-2017, 08:53 PM   #5
2017-BRZ
the gears are too short for that really.
Old 03-11-2017, 11:57 PM   #6
In the owners manual along with all sorts of other cool things you can do.
8RZ (03-29-2017), Kimsey47 (03-28-2017), Stang70Fastback (03-29-2017), strat61caster (03-28-2017), tCsonfrs (03-13-2017)
Old 03-12-2017, 12:20 AM   #7
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Oh damn...got to break out the manual again !!!
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
Tcoat (03-12-2017)
Old 03-12-2017, 12:30 AM   #8
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
you can turn it on or off using the instrument panel display
go to settings -> GSI and then on or off
tacos is offline   Reply With Quote
Old 03-28-2017, 07:47 PM   #9
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
I've been trying my best to abide by the carrot... Dang thing says I should be in 6th at 35mph!
tfp is offline   Reply With Quote
Old 03-28-2017, 08:10 PM   #10
strat61caster
strat61caster's Avatar
AT?
That would be <2k rpm on a first gen MT, let alone the shorter rear end on the '17 MT.
I'll cruise at 35 mph in 5th gear once up to temp, just a hair over 2k rpm, couldn't imagine putting it in 6th, sure it's possible, just doesn't feel right.
ineedyourdiddly
Old 03-28-2017, 11:41 PM   #11
Poodles
Drives: 2015 Series.Blue
Flat level ground, 6th at a tad over 35MPH is fine. ANY hill and it's going to bog.
The Following User Says Thank You to Poodles For This Useful Post:
strat61caster (03-29-2017)
Old 03-29-2017, 12:08 AM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
It adapts to driving conditions/style somewhat.
Old 03-29-2017, 09:16 AM   #13
I tried to resist but every single time I read that title I cringe a little
JD001 (03-29-2017)
Old 03-29-2017, 12:03 PM   #14
strat61caster
Did it this morning, I remembered wrongly about how the car cruised at 1.5k-2k, I think I might be enjoying a bump in fuel economy on my next tank as I was keeping the revs over 2k all the time.
ineedyourdiddly
5th Gear "Mini-Grind" BRianZ Issues | Warranty | Recalls / TSB 63 07-18-2015 05:12 AM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 01:26 AM
how to display on the dashboard what gear i am driving in sci3 Scion FR-S / Toyota 86 GT86 General Forum 17 09-02-2014 12:28 AM
"This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind DoomsdayJesus Issues | Warranty | Recalls / TSB 108 04-29-2014 01:15 AM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
